Large Notch In Support Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 05:35 AM   #1
Rewards Points: 14
large notch in support beam
In the basement there are two identical "beams". Approx 16' long made up of three 2X8's. Supported at each end by foundation wall and in the middle (7' from one end and 9' from the other end ) by a concrete post approx 12" square. At one end a "notch" was cut out for some reason. (see photo) Notch is 5"X6" and about 2' from foundation wall. Under the notch is a "pole jack" to support it. What can I do to permanently remove the pole jack? Load bearing wall? Not sure. Beam runs perpendicular to joists. There are walls above this beam on the 1st. and 2nd floors. Apologies for any incorrect terms. Need more info or pictures? Thanks.
large notch in support beam-support1small.jpg   large notch in support beam-support2small.jpg   large notch in support beam-support3small.jpg   large notch in support beam-support4small.jpg
kadgar is offline   Reply With Quote
Old 01-26-2009, 05:54 AM   #2
the Musigician
DangerMouse's Avatar
wow... i wouldn't attempt to move that pole jack..... very dangeroous.
why do you want to?
now if i HAD to, i'd consider a NEW support beam (probably LVL) installed BEFORE i attempted to remove the old one.
and i'd certainly talk to my engineer/architect friend first to have him evaluate the situation.
but the guys here will have better suggestions, i'm sure....
DM
Old 01-26-2009, 06:58 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
This could be a little en-voled for a DIY'er, but ! If you need to remove the lolly column here are some idea's
1) I agree with the mouse. you will need to build a temporary wall under all those floor joists on either side of the existing girder, No more then 2' back. i would recommend putting a 6x6 on the floor { looking at the photo's it appears the house has some age to it which leads me to believe the floor could be 2" thick or less,the 6x6 will help from having the floor crack and sink.} install a top plate and add your 2x4 wall studs making them a little longer to help take the tension off the girder.you could even use a jack to lift the beam slightly then install your stud.
get some LVL's (which will become wider then the existing girder) or three Doug fir 2x8's that should bring you just about flush with the existing girder.
Cut out the existing girder centered on the next lolly column. measure the length and spike two together and then install. once in place install your third 2x8 and spike that together. Then I would install two pieces of 1/4" plates on either side of the seam above the supporting Lolly column threw bolted. then remove the walls.
2. you can just leave the column. Its doing its job as long as its on a proper footer. or just frame your wall and leave it there. frame your two foot wall from the column to the foundation wall, you say its 2' correct ?. doing it this way you will need to support the wall on some type of footing. do you want to break up the floor? BOB
Old 01-26-2009, 07:25 AM   #4
the Musigician
me, i wonder why the holes were cut to begin with... i'm guessing no longer existing ductwork?
can't see the floor, but if they put in the lallys, they probably have an ok floor, or put wood under them.
if it was me, i'd sister an additional 2x to what's there to add strength along that area. (if you plan on keeping it) but NOT to replace the added beam.
involved? yes...
do-able? maybe with a helper? sure!
buletbob sez he'll be right over to help! Po)
DM
Old 01-26-2009, 08:45 AM   #5
Registered User
Termite's Avatar
BuletBob's pretty much got it right! No way to repair that beam...That notch completely compromises it structurally. No way to remove the lally column without replacement of the beam. The beam could definately be replaced as long as temporary walls were erected to support the joists that bear on the beam.
Old 01-26-2009, 08:47 AM   #6
Registered User
Termite's Avatar
In the 2nd pic it looks like there's another beam cut even worse in the background. Is that the case???
Old 01-26-2009, 08:55 AM   #7
the Musigician
i saw that too KC, looks like they're sagging too.....
all i can say is WHAT WERE THEY THINKING???
DM
Old 01-26-2009, 09:04 AM   #8
joed's Avatar
Rewards Points: 12,018
The third picture looks like a close up of the second beam( note the 1x instead of 2x spanning the gap). Probably the plumbers running a drain line did this.
Old 01-26-2009, 11:13 AM   #9
Rewards Points: 562
Merely guessing, but was this house heated with the old style steam or hot water method once upon a day?? Looks a bit big for a drain line even!! They had enough room up in that floor joist bay for a drain. This looks like WHY the term wood butcher was invented!! If your going to replace one,,,might as well replace BOTH of those!!
4just1don is offline   Reply With Quote
Old 01-26-2009, 01:41 PM   #10
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Holy Crap!
- Build Well -
Old 01-26-2009, 01:45 PM   #11
Maybe look into installing supports (Completely supporting the underside of the entire compromised areas of the beam), to new concrete footings.
- Build Well -
Old 01-26-2009, 02:24 PM   #12
The only good thing I can say is that those are very square and well-cut notches. When they installed plumbing in my house many decades ago, it's clear they used chisels, hatches, and possibly an ax on every piece of wood that got in their way of their pipes. Here it looks like they took a reciprocating saw to the sides and chiseled it out. I bet they wondered why the wood was so tough to get through.
I'm guessing it was a duct. The structural members I've seen that have been butchered for pipes were usually two diagonal cuts leaving a triangular cut for the pipe, not a square one. Why chisel when you don't have to?
Or maybe he thought square notches would demonstrate better workmanship.
scowl is offline   Reply With Quote
Old 01-26-2009, 02:30 PM   #13
Registered User
Termite's Avatar
Actually, square holes and notches...Although neat-looking...Are the worst thing you can do to a beam or any structural member. Loads are concentrated to the corners of a square, which can lead to failure. Round holes and rounded notches take less away from the beam because the loads distribute around the notch or hole better, structurally speaking.
Old 01-26-2009, 02:39 PM   #14
Yes I should have put a with my remark!
Old 01-26-2009, 03:12 PM   #15
the Musigician
Originally Posted by AtlanticWBConst. View Post
Holy Crap!
i've seen worse......
DM
How to add another support beam under floor joists LOStouten Carpentry 3 11-13-2008 11:55 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
