-   -   large notch in support beam (http://www.diychatroom.com/f19/large-notch-support-beam-36850/)
kadgar 01-26-2009 04:35 AM
4 Attachment(s)
In the basement there are two identical "beams". Approx 16' long made up of three 2X8's. Supported at each end by foundation wall and in the middle (7' from one end and 9' from the other end ) by a concrete post approx 12" square. At one end a "notch" was cut out for some reason. (see photo) Notch is 5"X6" and about 2' from foundation wall. Under the notch is a "pole jack" to support it. What can I do to permanently remove the pole jack? Load bearing wall? Not sure. Beam runs perpendicular to joists. There are walls above this beam on the 1st. and 2nd floors. Apologies for any incorrect terms. Need more info or pictures? Thanks.
DangerMouse 01-26-2009 04:54 AM
wow... i wouldn't attempt to move that pole jack..... very dangeroous.
why do you want to?
now if i HAD to, i'd consider a NEW support beam (probably LVL) installed BEFORE i attempted to remove the old one.
and i'd certainly talk to my engineer/architect friend first to have him evaluate the situation.
but the guys here will have better suggestions, i'm sure....
DM
buletbob 01-26-2009 05:58 AM
This could be a little en-voled for a DIY'er, but ! If you need to remove the lolly column here are some idea's
1) I agree with the mouse. you will need to build a temporary wall under all those floor joists on either side of the existing girder, No more then 2' back. i would recommend putting a 6x6 on the floor { looking at the photo's it appears the house has some age to it which leads me to believe the floor could be 2" thick or less,the 6x6 will help from having the floor crack and sink.} install a top plate and add your 2x4 wall studs making them a little longer to help take the tension off the girder.you could even use a jack to lift the beam slightly then install your stud.
get some LVL's (which will become wider then the existing girder) or three Doug fir 2x8's that should bring you just about flush with the existing girder.
Cut out the existing girder centered on the next lolly column. measure the length and spike two together and then install. once in place install your third 2x8 and spike that together. Then I would install two pieces of 1/4" plates on either side of the seam above the supporting Lolly column threw bolted. then remove the walls.
2. you can just leave the column. Its doing its job as long as its on a proper footer. or just frame your wall and leave it there. frame your two foot wall from the column to the foundation wall, you say its 2' correct ?. doing it this way you will need to support the wall on some type of footing. do you want to break up the floor? BOB
DangerMouse 01-26-2009 06:25 AM
me, i wonder why the holes were cut to begin with... i'm guessing no longer existing ductwork?
can't see the floor, but if they put in the lallys, they probably have an ok floor, or put wood under them.
if it was me, i'd sister an additional 2x to what's there to add strength along that area. (if you plan on keeping it) but NOT to replace the added beam.
involved? yes...
do-able? maybe with a helper? sure!
buletbob sez he'll be right over to help! Po)
DM
Termite 01-26-2009 07:45 AM
BuletBob's pretty much got it right! No way to repair that beam...That notch completely compromises it structurally. No way to remove the lally column without replacement of the beam. The beam could definately be replaced as long as temporary walls were erected to support the joists that bear on the beam.
Termite 01-26-2009 07:47 AM
In the 2nd pic it looks like there's another beam cut even worse in the background. Is that the case???
DangerMouse 01-26-2009 07:55 AM
i saw that too KC, looks like they're sagging too.....
all i can say is WHAT WERE THEY THINKING???
DM
joed 01-26-2009 08:04 AM
The third picture looks like a close up of the second beam( note the 1x instead of 2x spanning the gap). Probably the plumbers running a drain line did this.
4just1don 01-26-2009 10:13 AM
Merely guessing, but was this house heated with the old style steam or hot water method once upon a day?? Looks a bit big for a drain line even!! They had enough room up in that floor joist bay for a drain. This looks like WHY the term wood butcher was invented!! If your going to replace one,,,might as well replace BOTH of those!!
AtlanticWBConst. 01-26-2009 12:41 PM
Holy Crap!
AtlanticWBConst. 01-26-2009 12:45 PM
Maybe look into installing supports (Completely supporting the underside of the entire compromised areas of the beam), to new concrete footings.
scowl 01-26-2009 01:24 PM
The only good thing I can say is that those are very square and well-cut notches. When they installed plumbing in my house many decades ago, it's clear they used chisels, hatches, and possibly an ax on every piece of wood that got in their way of their pipes. Here it looks like they took a reciprocating saw to the sides and chiseled it out. I bet they wondered why the wood was so tough to get through.
I'm guessing it was a duct. The structural members I've seen that have been butchered for pipes were usually two diagonal cuts leaving a triangular cut for the pipe, not a square one. Why chisel when you don't have to?
Or maybe he thought square notches would demonstrate better workmanship.
Termite 01-26-2009 01:30 PM
Actually, square holes and notches...Although neat-looking...Are the worst thing you can do to a beam or any structural member. Loads are concentrated to the corners of a square, which can lead to failure. Round holes and rounded notches take less away from the beam because the loads distribute around the notch or hole better, structurally speaking.
scowl 01-26-2009 01:39 PM
Yes I should have put a :) with my remark!
DangerMouse 01-26-2009 02:12 PM
Originally Posted by AtlanticWBConst. (Post 219436)
Holy Crap!
i've seen worse......
DM
