Large Frameless Mirror Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-29-2008, 10:10 AM   #1
Rewards Points: 274
large frameless mirror install
I need to have 2 large frameless wall mirrors installed on new construction bathrooms (level walls). One is 42" x 48", the other is 42" x 72". They were custom cut and the glass company wants $250 to install these. I was going to install myself but I started thinking about risk of breakage during transporting and installing. (ie; penny-wise, pound foolish)Opinions?????.... Also, do I need to use mastic or could I just use clips if I hit studs.
P.S. They would also install the sliding shower doors included in the $250
ugabulldog is offline   Reply With Quote
Old 02-29-2008, 11:41 AM   #2
Rewards Points: 150
DIY forum....diy. Actually I just took a mirror (4' x 5') out of a bathroom. I didn't know how it mounted until I got it off. The bottom sat in a J-channel that ran the width of the mirror. The channel was screwed into the wall and took all the weight. There were blobs of adhesive that kept the mirror from falling away from the wall. Based on what I saw, it seems pretty easy to DIY. If you need to transport it, you will probably need some rig to keep it vertical. I would also suggest full coverage (long sleeves and leather gloves) just in case something breaks. Better to only loose the glass rather than the glass and a lot of blood.... Good luck
steve1234 is offline   Reply With Quote
Old 02-29-2008, 12:35 PM   #3
Jack of Some Trades
Wood Butcher's Avatar
to me it depends on how much the mirrors cost in the first place. if the set of two cost $125 or less you basically have two chances to DIY before you start losing money.
clips should be fine as long as you have them in studs, use both if you are really concerned, can't hurt
Wood Butcher is offline   Reply With Quote
Old 02-29-2008, 04:49 PM   #4
Handyman
Rewards Points: 512
$250 to install two large mirrors and shower doors seems pretty reasonable to me
canadaclub is offline   Reply With Quote
Old 02-29-2008, 05:50 PM   #5
Rewards Points: 274
I have decided to let the pros do this one...
Old 02-29-2008, 06:36 PM   #6
Handyman
Rewards Points: 512
Good Idea. Are they insured?
Old 03-01-2008, 11:27 AM   #7
Jack of Some Trades
if you don't mind sharing, how much are they charging you for the actual mirrors?
Old 03-01-2008, 12:05 PM   #8
Remodeler
MinConst's Avatar
Excellent choice.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 03-01-2008, 01:26 PM   #9
Rewards Points: 274
The mirrors were not that much, I forget exactly, between $100-$200 each. The shower doors were expensive though, like $480 for brushed nickel finish which the wife insisted on. I am looking at about $1,000 for all including install.
Old 11-01-2008, 03:46 PM   #10
What was the result?
How did the pros install your mirrors?
abradley is offline   Reply With Quote
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 03:01 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 05:28 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 10:17 PM
Filling a Large Tub Blaze25 Plumbing 2 11-14-2006 06:23 AM
