Old 04-27-2010, 01:02 PM   #1
Post
Large Bookcase Support
Want to add 10' x 10' bookcase in room. Wall that bookcase would sit on is parallel to floor joists. Floor joists are 2x10 crossing 16' span. Access beneath floor is difficult as it would require messing with ducts, pipes, etc. Worried that joists are not strong enough to support bookcase's added weight. Could send beam across span above bookcase and hang it from that. Would be a lot of work and would prefer someone to tell me that floor should support bookcase.
brownmoose is offline   Reply With Quote
Old 04-27-2010, 01:29 PM   #2
the Musigician
DangerMouse's Avatar
In most cases, the floor SHOULD handle it just fine. The edges are supported by rim joists or sill plates and should hold that weight easily enough. I'd add some screw-in support along the back of the case to the wall studs for tip stability/security as well.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-27-2010, 03:48 PM   #3
It was a dark and stormy
Yoyizit's Avatar
100 cu. ft @ 35#/cu. ft. max gives 3500#, but rows of books probably are less dense than this, on average.
"According to the founder of online bookseller Alibris.com, an
average-sized book weighs 12 ounces. " and 500 sheets [a 2" stack] of 8-1/2 x 11 copy paper weighs 5# [46#/cu.ft.].
The deeper the bookcase, the more the weight will be transferred to adjacent joists rather than stressing the subfloor.
Tags
joists bookcase support
supporting large bookcase brownmoose Carpentry 5 04-28-2010 02:59 PM
Building a large Fish Tank - How? darenrogers General Discussion 3 01-20-2010 07:50 PM
large notch in support beam kadgar Building & Construction 18 01-29-2009 11:24 PM
Support for 5ft bookcase shelves dbldee20 Carpentry 5 01-07-2009 09:06 AM
How to properly support joists for a large fishtank michaelbarron Building & Construction 8 12-07-2008 12:21 AM
