Old 11-13-2012, 05:15 PM   #16
Large aquarium dead load on floor
Thanks for all the suggestions and help! Ive decided to leave things be the way I have them, but I also stepped down a little in tank size to a 75 gallon which lessens the weight a fair amount.
Ill post a few pics once done!
atljar is offline   Reply With Quote
Old 11-14-2012, 10:22 AM   #17
at 160# per SqFt load, you don't need to do anything on a normal house floor.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-14-2012, 10:52 AM   #18
DIY or die !
If I were you, I would basically build a pier system underneath the loaded area of the floor. I would also connect the floor joists to the wall studs laterally.
Basically a laced post box system composed of 4 4x4s laced together has a safety factor of 32,000lbs. This would be more than adequate. This resists all 3 dimensions of load, as well as racking & twisting.
Like this..... just prettier http://www.flickr.com/photos/teex/4116014818/lightbox/
Or if you're feeling cheap, just use some diagonal bracing into the wall studs for added support.
EDIT: I see you changed your mind. Good luck with the tank !
I have my 55 gallon in the BASEMENT
lewisthepilgrim is offline   Reply With Quote
Old 11-14-2012, 11:28 AM   #19
Agree. People stick over 1000# of full refrigerator on their kitchen floor and think nothing of it. I used to have a 2200# waterbed on 2 x 8 x14', 16" center floor joists. Had that up there for 15 years and never as much as a hairline crack in the plaster/lath cieling. Bed covered 6 floor joists.
danpik is online now   Reply With Quote
Old 11-19-2012, 12:52 PM   #20
Architect
What house is designed with a 160# uniform live load?
jcarlilesiu is offline   Reply With Quote
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 06:43 PM
large, soft areas in newly laid tongue & groove floating floor dfeigin Flooring 0 08-15-2011 02:19 AM
How to reinforce floor for a 210g aquarium?? secuono Flooring 3 08-12-2011 10:35 AM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 03:47 PM
Floor Weight Load RalphPeters Flooring 0 02-08-2010 02:16 PM
