Lap Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 03:05 PM   #1
Rewards Points: 150
Lap Siding
Looking for the 16 x 20 garage
For the homeowners association have to use lap siding or stucco
No T-11 and no vinyl siding
I have a lot of experience with the hardie lap siding and I like it alot, just would be nice if they came in lengths of 16 and 20 so I dont have to worry about joints.
Wanted to see if anyone would recommend a lap siding that comes in 16 or 20 foot lengths???
If you do, would you recommend it?
Any suggestions?
canyonbc is offline   Reply With Quote
Old 01-12-2010, 03:57 PM   #2
Rewards Points: 1,016
FYI - there are available 4'x8' sheets that install like T111 but have stucco pattern and appearance.
Old 01-12-2010, 04:02 PM   #3
Rewards Points: 150
Really?
Did not know that, where do you by them at?
How do they install?
Have you or anyone else used them?
Old 01-12-2010, 06:24 PM   #4
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Any suggestions?
LP smart siding is a decent product. It is quite a bit easier to install than Hardi Lap. If you install it correctly, it is a 25 year product. Perfect for a garage.
Kevin
http://www.lpcorp.com/smartside/
Kevin M. is offline   Reply With Quote
Old 01-12-2010, 08:03 PM   #5
Rewards Points: 150
Kevin
I will check this out, is the the masonite siding??
Old 01-12-2010, 08:31 PM   #6
Kevin M.'s Avatar
Rewards Points: 150
No. It's quite a bit better product. It is a wood base similar to OSB with a protective layer. If it is installed correctly, it should easily last 20 years or so.
Kevin
Old 01-12-2010, 09:20 PM   #7
Rewards Points: 150
Kevin
Kevin,
Thanks, I will head to the lumber yard tomorrow after work.
Do you know what lengths it comes in?
I am going to look up there website right now.
Thanks again
Mike
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-22-2009 11:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
