Laminated Post. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 11:23 PM   #1
Laminated post.
Getting ready to by a 40x64 bole barn garage kit from Menards, and was going to go with laminated post instead of solid. On the laminated post the truss sit in the middle of the three 2x6's, but how about on the corner post where the trusss is nail to the outside of the post?, not sure if you cut them or they give you a special posts for the corners.
Thanks for any info you can give me!
Bigby is offline   Reply With Quote
Old 05-19-2011, 06:38 AM   #2
Kit??? I have never done a 'kit' that large, but I suspect some cutting is needed. If it is indeed a kit, there should be directions supplied, use them.
Old 05-19-2011, 08:39 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
your post is not clear..Pics will help
Millertyme is offline   Reply With Quote
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 03:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 09:01 AM
Replacing a 6x6 post with a laminated wood beam wazzie Remodeling 3 03-21-2009 10:18 AM
