Laminated Flooring - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 04:13 AM   #1
laminated flooring
As below my floor boards in hall have warpped I also noticed a small warp in the bedroom . On top of this one small portion of our chimney
breast is moulding and the artexed is chalk???
our ground is clay so in the heavy rain the water will sit on top some times
kashucth1 is offline   Reply With Quote
Old 08-01-2012, 04:56 AM   #2
Remodeling Contractor
So now you know you have a moisture problem. Next is to find it and fix it. Do you have a crawlspace or basement? Are there gutters with downspouts leading the water at least 15 feet from the foundation? If you run your bath fan 24 hours a day it will help remove some of the moisture until you can resolve the root problem. run dehumidifier in the area where the wood is buckled, it may help.
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-18-2012 11:51 PM
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 08:55 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
price of vinly flooring compared to laminated hardwood flooring dollyooooo Flooring 1 05-13-2009 12:29 PM
