Laminate Wooden Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 06:44 PM   #1
laminate wooden beam
How can I laminate a wooden beam to replace a 6"x12" BC Fir 12 feet long?
BaxSmith is offline   Reply With Quote
Old 04-02-2011, 06:56 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The most obvious answer to your vague question is.....
To obtain a 6 x 12 laminated dimension you need (3) 2x12 x 12' with 2 pieces of 3/4" plywood sandwiched between the layers. (or just 4 - 2x12's )
This equals 4-1/2" plus 1-1/2" ..........
and (1) 3/4 x 6" x 12' added to the top or bottom to bring the 11-1/4" up to 12"
Is this what you were asking?
tcleve4911 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Removing sag from wooden beam Stevo Building & Construction 4 07-27-2008 09:15 AM
