Laminate Flooring On Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 05:35 PM   #1
laminate flooring on cement
I am installing laminate flooring on cement slab. Do I need underlayment?
praysing is offline   Reply With Quote
Old 08-26-2012, 08:40 PM   #2
Rewards Points: 3,628
You'll at least need a vapour barrier if you don't already have one under your slab,and if you do have one then probably an underlayment yes.
Canarywood1 is offline   Reply With Quote
Old 08-26-2012, 08:57 PM   #3
Rewards Points: 13,732
It's all right there on the box of flooring, not there you say then look on the companys web site for install directions.
There's hundreds of differant companys making it, and even within the one company there's diffeant types they may sell, all with differant needs to install correctly.
So there is no one ansewer for all laminites.
Is this floor below grade? If so there's some laminites that can not be used.
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 04:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
