Laminate Counter Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 08:56 PM   #1
Newbie Bill
Rewards Points: 520
laminate counter removal
Hey Guys,
I will be removing my old countertops in the coming month or so and tried a small area today to see what I am up against.
In the photo below you see the laminate goes up the wall about 3 or 4 inches. I unscrewed the countertop from the cabinet and lifted. The countertop tilts up very easily, but the backsplash portion seems really solid.
I was hoping the backsplash portion wasn't attached to the wall. Are these types of backsplashes usually secured to the wall? With nails/screws/ or heaven forbid, glue?
Any suggestions for cutting the laminate right in the curved corner between horizontal and vertical?
Or should I just lift and rip?
UPDATE: I just went and lifted this area again and twisted. The backsplash loosened up just fine. However, I'm not sure how I am going to do this for the main area. It is U shaped. Any suggestions.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 10-10-2009, 11:09 PM   #2
DIY staff
Rewards Points: 7,174
I remove these all the time.
First cut the caulk at the top edge.
Second remove any screws holding it to the cabinets
Sawsall the top at the sink opening
Pry it up and break or saw the backsplash behind the sink.
Carry it out.
Wash your hands.
Get a cup of coffee.
---MIKE
Old 10-12-2009, 11:37 AM   #3
LeviDIY's Avatar
Rewards Points: 252
Mine were glued... rrrrrrrrrrr......
LeviDIY is offline   Reply With Quote
Old 10-12-2009, 12:24 PM   #4
Newbie Bill
Rewards Points: 520
Well I removed the tiles above the laminate back splash and then cut the caulking.
Then I pulled. It moved freely. So this one wasn't glued or screwed. Thank god...
Bill
Laminate Counter Tops, clear coat? joedreamliner787 Painting 9 06-16-2011 04:55 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 12:53 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 07:34 PM
Repairing scratch in laminate counter Keyo77 General DIY Discussions 2 02-03-2008 02:00 PM
