Laid Up Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 05:08 PM   #1
laid up stone
I have laid up stone for a small structure which I want to install a door. The stone is irregular around the opening of the proposed door. How do I construct a frame which will be air tight against the stone surface?
paul m is offline   Reply With Quote
Old 12-30-2008, 06:54 PM   #2
Rewards Points: 1,232
As a rule, at the edges you lay the stone to be plumb and flush. If it is already laid, then you can only build it up with mortar to provide a plumb and square corner. You can also edge doors, corners and windows with brick, something like this:
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 06:38 AM
Masonry Stone Archway jp33 Remodeling 8 01-31-2008 07:23 PM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 05:03 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
