Lag Screws Attaching Header To Wall . - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 08:38 AM   #1
lag screws attaching header to wall .
I am using a 2x6 header attached to garage wall with lag screws . Joist hangers will support 2x6 joists for flat carport roof ,
As there is a thin layer of stucco on wall, I will use 3/8 by 3 1/2 inch lag screws . The header is 20 feet long and the span for joists will be 10 feet.
My questian: Do I need two lag screws in each 2x4 stud? Or is every second stud adequate? Or one lag screw in each stud?
Tom Hall is offline   Reply With Quote
Old 02-23-2012, 09:26 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
Yep, but why would you over kill like that, why don't you use 1X4s for the ceiling joists and use 3/4X12 inch lags in each. Oh and a 20 foot 2X6 header is way to heavy, why bother with a header at all.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-23-2012, 07:52 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
i think he means a ledger which the joists but into. as for attaching it.. you should be able to get away with just 3 1/2" spikes aka 16 penny nails
woodworkbykirk is offline   Reply With Quote
Old 02-23-2012, 07:58 PM   #4
Rewards Points: 528
The real problem is how are you going to flash this?
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
Tom Struble (02-23-2012)
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
remove door header on load bearing wall belle18 Building & Construction 12 11-27-2011 10:16 AM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 07:34 PM
Attaching A lot of wood to wall MakinItHome Building & Construction 4 08-22-2009 07:26 PM
