L Bolts In Concrete Slab... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 06:26 PM   #1
L bolts in concrete slab...
I'm pouring a 10' x 16' concrete slab that will someday have a garage/shed built on top of it. The slab will be about 12" deep around the edge and 7-8" in the center. I'm going to install some "L bolts" (I hope that's the correct term) when the slab is poured. I'm thinking that 1/2" bolts that are 8" long should suffice, but I'm not sure how many to use. We're in earthquake country, so I'd like to overdo it a bit. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 12-02-2009, 07:20 PM   #2
PHB Construction LLC
Paulie's Avatar
We have a specific distance and codes up here in MI. I don't know about earthquake country but I would search the codes in your area. Those L bolts are called many things, sill bolts, foundation bolts.....
Paulie is offline   Reply With Quote
Old 12-02-2009, 09:21 PM   #3
Yes, I'll check the code requirements here. Just out of curiosity, do you know what the requirements are in your neck of the woods?
Old 12-02-2009, 10:30 PM   #4
Rewards Points: 1,016
A google on foundation bolts or similar will find several items.
When I built my 24x30 workshop in SoCal I had to do shear walls in each corner, with the shear walls connected via brackets to J-bolts in the foundation. This required the J-bolts to be very carefully placed to fall next to the shear wall ends and the corner. Then j-bolts about every 4-6 feet if i recall.
Old 12-02-2009, 10:33 PM   #5
Another item I can't see if in your pictures - a ufer for the electrical ground. Even if not you are planning electical sub panel for the detached building, suggest to install one now since it's so easy to do - then it's there for the future.
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
