Old 09-30-2010, 01:08 PM   #1
Kraft paper on ceiling joists for plaster
Hello,
Kraft paper on ceiling joists for plaster?
This comes up because I am replastering a ceiling in my 1904 home. I took down a sagging and cracked wood lath and 3 coat plaster ceiling.
I am going back with 3 coat and plaster over ribbed lath. I was talking with the plaster who I will be working with and we discussed the need to put Kraft paper or polyethylene vapor barrier over the bottom of the ceiling joists. The thought of doing this only came up from an article I read at http://www.nps.gov/history/hps/tps/briefs/brief21.htm, which states to do this.
I can understand why they would want that done if the ceiling you are plastering is below an attic or unheated/conditioned space and maybe this is what the article is simply referring to.
My situation puts that ceiling below a 2nd story room that is heated and cooled. So I believe that in my sitation I won't have to worry about condensation on the joists.
Please provide your experience and insights into this if you would.
Thanks,
Jeffrey
jefsboys is offline   Reply With Quote
How to best level uneven ceiling joists? luvdairish Building & Construction 1 09-20-2010 12:17 AM
When cutting ceiling joists, how thick should the header be? dwoloz Building & Construction 11 08-20-2010 04:58 PM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 10:12 AM
Ceiling joists spans drywall in a basement? Indianer Drywall & Plaster 14 06-09-2008 03:51 PM
Removing 2nd Floor Ceiling Joists BigJimmy Building & Construction 1 06-06-2008 02:43 PM
