Kraft Faced Batt Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 08:37 AM   #1
Kraft faced batt insulation
Probably question for guys in commercial business. How do you attach Kraft faced batt insulation to steel studs (20 gauge) ?
Am I required overlap the flanges and staple them to the edges of steel studs or is there different approach to attaching the insulation.
Thanks for your help. Charles
Charles_cz is offline   Reply With Quote
Old 06-09-2009, 09:29 AM   #2
Be sure to order full-width batts when installing insulation in steel studs. Batts for wood walls are typically 14 or 22 inches to allow for the space taken up by the stud. With steel framing the studs are hollow and require a full 16- or 24-inch batt, depending on the stud spacing.
To install the batt insulation, simply tuck one side of the batt inside the open flange of the stud and press the other side into the wall cavity. Friction should hold the batts in place until the gypsumboard is installed
However, I would use full unfaced then put a poly vapor barrier up.
JonM is offline   Reply With Quote
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 07:23 AM
Radiant barrier with faced insulation? luci468 Building & Construction 1 07-18-2009 03:49 PM
19" spaced joists - foil faced insulation? CWorth Remodeling 3 03-21-2009 12:26 PM
Kraft Faced Batts in Interior Wall Earnie Building & Construction 2 01-24-2008 08:52 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 01:23 PM
