KoolKrete Surface - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2007, 08:30 AM   #1
KoolKrete Surface
Greetings--
Not sure where to post this-- so here goes--
The concrete decking surrounding my pool and the patio is surfaced with somthing that was called KoolKrete (sp?). This was in place when we bought the house.
Its a coating that causes the sun's heat to dissipate. It works great-- heat of the day we can walk barefoot w/o a problem.
Question-- Where can I get this stuff ? There are a few small places where its beginning to come off. I thought it best to catch this before it gets worse.
Question- It's dirty. I thought that cleaning it with a power washer would work. It helped some, but apparently its become stained. Its not stained in spots like where somthing has been sitting-- its large open areas where just daily dirt has set.
Anyone had experience cleaning this stuff ? I've got a 2600 psi washer. I am afraid that if I rent a stronger model, it may peal off the coating. I've tried applying a concrete cleaning soap-- no help.
Piney is offline   Reply With Quote
Old 03-14-2007, 06:04 AM   #2
I have not heard of this material but then again their are so many out their.What you might do is run a search by name and find the home psge most will tell you where you can buy it and also most have either product aplication and treatment info or a company phone number to get tech advice.Sorry I couldnt be of more help
clasact is offline   Reply With Quote
Old 04-30-2007, 12:06 AM   #3
try looking for it by the name; kool deck, its a cemetious coating.. basically plaster & polymer.. applied by brush splashing & trowel knock down
POOLMANinCT is offline   Reply With Quote
Rubber playground surface toolbag General DIY Discussions 19 05-16-2013 03:45 PM
Deck surface mt232 General DIY Discussions 11 05-01-2007 02:32 PM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 08:23 AM
new hot surface ignitor, still no luck steve1971 HVAC 3 11-09-2006 05:02 PM
Removing popcorn from ceiling? Doug Crf Painting 5 05-22-2006 08:23 AM
