-   -   KoolKrete Surface (http://www.diychatroom.com/f19/koolkrete-surface-7060/)
Piney 03-12-2007 08:30 AM
KoolKrete Surface
Greetings--
Not sure where to post this-- so here goes--
The concrete decking surrounding my pool and the patio is surfaced with somthing that was called KoolKrete (sp?). This was in place when we bought the house.
Its a coating that causes the sun's heat to dissipate. It works great-- heat of the day we can walk barefoot w/o a problem.
Question-- Where can I get this stuff ? There are a few small places where its beginning to come off. I thought it best to catch this before it gets worse.
Question- It's dirty. I thought that cleaning it with a power washer would work. It helped some, but apparently its become stained. Its not stained in spots like where somthing has been sitting-- its large open areas where just daily dirt has set.
Anyone had experience cleaning this stuff ? I've got a 2600 psi washer. I am afraid that if I rent a stronger model, it may peal off the coating. I've tried applying a concrete cleaning soap-- no help.
clasact 03-14-2007 06:04 AM
I have not heard of this material but then again their are so many out their.What you might do is run a search by name and find the home psge most will tell you where you can buy it and also most have either product aplication and treatment info or a company phone number to get tech advice.Sorry I couldnt be of more help
POOLMANinCT 04-30-2007 12:06 AM
try looking for it by the name; kool deck, its a cemetious coating.. basically plaster & polymer.. applied by brush splashing & trowel knock down
