Knots In Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 10:41 AM   #1
Rewards Points: 190
Knots in Studs
Hi,
I'm in the middle of building our house (not me, but a builder is building it). I took a walk through and noticed a couple of studs that have knots and are missing some wood on the edge of the stud, so it's not a complete 2x4. I didn't have my camera with me yesterday and it's kind of hard to describe.
I read on here that when they design a house, they take into account defects in the studs and it should not hurt anything structurally. I find this a little hard to believe, but I'm not an expert. That's why I'm here.
At what point should a stud be rejected? When half of it (so it's ~2x2) is gone in a length of about 6"? Am I just being paranoid?
Thanks in advanced...
wiz561 is offline   Reply With Quote
Old 08-17-2010, 11:08 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by wiz561 View Post
Hi,
If it is one here and there, I really doubt it will make a difference in the structure. If it was my house and the walls were still open, if it bothered me, I would ask for them to be replaced. Should only take a few minutes each to replace them if the walls are open and no utilities are run in the walls yet.
I like using select grade studs, it may not be practice on all jobs though due to cost. They are generally very nice quality, very clean and very true.
Jamie
jamiedolan is offline   Reply With Quote
Old 08-17-2010, 11:11 AM   #3
Old School
Willie T's Avatar
In most cases, a 2x4 is little more than something to hang wall finishing material on. Go look at the amount of the material cut out of plumbing walls where the waste pipes run through.
I wouldn't lose any sleep over it.
Willie T
Old 08-17-2010, 11:32 AM   #4
Rewards Points: 190
Thanks. You are correct in comparing it to the plumbing and conduits. It's just something you see and say "huh, that doesn't look good". But again, I'm not a builder, I'm just a regular person looking at some wood.
Thanks for the response!
Old 08-17-2010, 06:30 PM   #5
Registered User
Rewards Points: 4,912
What does the grade stamp (printing) on the stud read? http://books.google.com/books?id=jQr...uction&f=false
Be safe, Gary
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 07:59 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
