To Knock Down Or Not To Knock Down!! Help!!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 10:19 AM   #1
Smile
to knock down or not to knock down!! help!!!
so my wife and i are about to re-do our kitchen and would like to open up the space a lot. we want to knock down a wall dividing the kitchen from the dining room. we live in a ranch style house with no basement and just a crawl space in the attic on a concrete slab. we would like to remove the wall in the kitchen (a wall with a walk thru in it that measures 8' 7" on the left side and 7' on the right side with a 33.5" doorway) the beams in the kitchen ceiling run the same direction as the wall but the beams in the dining room run perpendicular. so i am not sure if it is load bearing or not. i know i have to re-route electrical but thats easy. please help!! thanks in advance!
willingboro81 is offline   Reply With Quote
Old 04-10-2011, 10:42 AM   #2
Rewards Points: 2,238
Hi!
From your description -
It sounds like that wall is load bearing.
rossfingal
Welcome to "DIY"!
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
willingboro81 (04-10-2011)
Old 04-10-2011, 01:24 PM   #3
Rewards Points: 1,016
Can you post pictures of the attic showing where the wall is below?
Old 04-10-2011, 03:04 PM   #4
i sure can here is a link to some pics i just took!
http://plixi.com/p/91320440
Old 04-10-2011, 03:38 PM   #5
Tizzer's Avatar
Rewards Points: 452
How about pictures we don't have to belong to facebook to view.
Tizzer is offline   Reply With Quote
The Following User Says Thank You to Tizzer For This Useful Post:
Willie T (04-10-2011)
Old 04-10-2011, 03:52 PM   #6
sorry! http://plixi.com/p/91320440
Old 04-10-2011, 06:12 PM   #7
Not enough pictures - (Good picture!) -
we have to see a/or somewhat "broader" shot(s) - if possible.
rossfingal
Old 04-10-2011, 06:19 PM   #8
rossfingal
ok let me see what i can do
Old 04-10-2011, 07:31 PM   #9
rossfingal
this is the best i can do as its a tight area for me to be in
http://plixi.com/p/91373750
Tags
bearing , load , wall
Am I asking too much to get Knock down to match titan7 Drywall & Plaster 1 12-15-2010 11:37 AM
orange peel or knock down?? or smoth?? scottyshome Remodeling 2 10-25-2009 08:53 AM
washer box knock outs help rocketdoctor Plumbing 1 07-03-2009 01:12 AM
Knock down application tips needed gmhut Painting 1 07-31-2008 10:30 PM
Periodic Knock in Pipe andarlite Plumbing 3 06-04-2007 02:39 PM
