Old 05-17-2007, 04:17 PM   #1
Default knee wall question
My friend has a wall the is non bearing and wants to make it into a knee wall inbetween the kitchen and living room. We removed all electrical and made the wall about 3'-6" or 4'.( not sure) right now the end wall moves back and forth. Placed a top on it and drilled a hole in the top plate and placed a 3/8" threaded rod (going to the basement). Tightened up on the rod and still wobbles. Did i mention the wall was built with 2x3 also. What are your suggestions to stop the wobbleing with out removing the entire thing and rebuilding with 2x4.. PLEASE HELP....
jscholl411 is offline   Reply With Quote
Old 05-17-2007, 04:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The best way to keep it from 'wobbling' is to attach it like a railing with a 'post' at the end. That means that you would have to take up part of the floor and 'bolt' a 6x6 fir post at the end of the wall - into the side of a floor joist.
The very end of the section would be a 4x4 fir post, notched and bolted. We double the top plates to create an 'overlap' of the wall framing (Cap them like exterior framed walls). We like to add 3" - 4" deck screws for at all the attachment points (Holds tighter than nails)
Last, we use 5/8" sheetrock on both sides. Much stiffer and firmer. You could use construction adhesive on the back sides of the SR when attaching too.
FWIW - This is the method that we always use when building a 1/2 wall and they are solid.
- Build Well -
Old 05-17-2007, 05:00 PM   #3
AtlanticWBConst.
thanks for the quick reply. Just to give a little more information. The wall is 5'-6" long 2x3 studs 1/2 sheetrock. directly under the wall is a doubled up 2x6 joist. Are you saying to put a 4x4 wood post at the wobbling end and secure it to the double joists? He has not taken off the existing sheetrock. I was thinking to rip it all down and start over but he dosent want to spend the time doing it.....Any ideas?
Old 05-17-2007, 05:25 PM   #4
AtlanticWBConst.
Basically, it's built all wrong (2x3's)
Seriously, rip it all down and build it with 2x4's and use a 4x4 fir post, notched and lagged onto the doubled floor joists. Use the 5/8" sheetrock etc.... (unless you like living with a wobbly wall)
- Build Well -
Old 05-17-2007, 06:34 PM   #5
Nother option, if you dont want to tear it down, is to add a little return wall, (make it an "L" shaped or a "T" shaped wall) to the end of it. 10" to 12" screwed to the end of the existing wall then attached to the floor would stiffen it up considerably.
send_it_all is offline   Reply With Quote
Old 05-31-2007, 05:04 PM   #6
Thank you all for all your help. We accually put in 2 2x3's and nailed them into the floor and the ceiling and sheetrocked around it. It made the wall more secure. It looks really nice also. Thanks again.
Old 05-31-2007, 05:17 PM   #7
Glad it all worked out for you with minimal re-working.
Now, we a just waiting to see the ''finished'' pictures....
- Build Well -
Old 10-10-2007, 02:30 PM   #8
Sorry the pictures took so long but here is the finished wall. wood trim still needs to be stained
More On This Topic
Hi! I'm Jeff Pence and I am with Bob Street today from Houdini Home Improvement in Lebanon, Ohio on behalf of Expert Village. In this clip, we are going to setting the sink on the pedestal stand using a little caulk to let it seat better and then... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about attaching our wall to concrete. Since our wall will be sitting on concrete, there is a couple of different ways that we can attach our wall to that concrete. The... Read More »
Rod McMahon for Expert Village we need to make a rip we could do that as well with a sawzall. We just rip this 3x4 right in half. We keep that line there I don't know if you could see that. Let me make it a little darker. I'm going to want to clamp this... Read More »
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
How to Install a Toilet
How to Install a Toilet by Expert Village
Ok, now I'm going to take the toilet, I've got it all in one piece already because its a used toilet and we're going to set it in place. Ok, now I'm a little bit up off the floor because my toilet is just now beginning to squish that wax ring down into... Read More »
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 11:14 AM
Knee Wall Not Level cibula11 Building & Construction 14 03-10-2007 07:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Floor and wall tile question irlizard Flooring 21 07-20-2006 03:35 PM
One more wall question J187 Building & Construction 7 05-25-2006 07:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
