-   -   knee wall question (http://www.diychatroom.com/f19/knee-wall-question-8525/)
jscholl411 05-17-2007 02:17 PM
knee wall question
My friend has a wall the is non bearing and wants to make it into a knee wall inbetween the kitchen and living room. We removed all electrical and made the wall about 3'-6" or 4'.( not sure) right now the end wall moves back and forth. Placed a top on it and drilled a hole in the top plate and placed a 3/8" threaded rod (going to the basement). Tightened up on the rod and still wobbles. Did i mention the wall was built with 2x3 also. What are your suggestions to stop the wobbleing with out removing the entire thing and rebuilding with 2x4.. PLEASE HELP....
AtlanticWBConst. 05-17-2007 02:31 PM
The best way to keep it from 'wobbling' is to attach it like a railing with a 'post' at the end. That means that you would have to take up part of the floor and 'bolt' a 6x6 fir post at the end of the wall - into the side of a floor joist.
The very end of the section would be a 4x4 fir post, notched and bolted. We double the top plates to create an 'overlap' of the wall framing (Cap them like exterior framed walls). We like to add 3" - 4" deck screws for at all the attachment points (Holds tighter than nails)
Last, we use 5/8" sheetrock on both sides. Much stiffer and firmer. You could use construction adhesive on the back sides of the SR when attaching too.
FWIW - This is the method that we always use when building a 1/2 wall and they are solid.
jscholl411 05-17-2007 03:00 PM
AtlanticWBConst.
thanks for the quick reply. Just to give a little more information. The wall is 5'-6" long 2x3 studs 1/2 sheetrock. directly under the wall is a doubled up 2x6 joist. Are you saying to put a 4x4 wood post at the wobbling end and secure it to the double joists? He has not taken off the existing sheetrock. I was thinking to rip it all down and start over but he dosent want to spend the time doing it.....Any ideas?
AtlanticWBConst. 05-17-2007 03:25 PM
Originally Posted by jscholl411 (Post 45409)
AtlanticWBConst.
Basically, it's built all wrong (2x3's)
Seriously, rip it all down and build it with 2x4's and use a 4x4 fir post, notched and lagged onto the doubled floor joists. Use the 5/8" sheetrock etc.... (unless you like living with a wobbly wall)
send_it_all 05-17-2007 04:34 PM
Nother option, if you dont want to tear it down, is to add a little return wall, (make it an "L" shaped or a "T" shaped wall) to the end of it. 10" to 12" screwed to the end of the existing wall then attached to the floor would stiffen it up considerably.
jscholl411 05-31-2007 03:04 PM
Thank you all for all your help. We accually put in 2 2x3's and nailed them into the floor and the ceiling and sheetrocked around it. It made the wall more secure. It looks really nice also. Thanks again.
AtlanticWBConst. 05-31-2007 03:17 PM
Glad it all worked out for you with minimal re-working.
Now, we a just waiting to see the ''finished'' pictures....:)
jscholl411 10-10-2007 12:30 PM
Sorry the pictures took so long but here is the finished wall. wood trim still needs to be stained
http://i101.photobucket.com/albums/m...1002071737.jpg
http://i101.photobucket.com/albums/m...1002071738.jpg
