Knee Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 12:09 AM   #1
Jordan83
Send a message via AIM to jordan83 Send a message via MSN to jordan83
I just purchased a cape cod home and the brisk chicago fall has kicked in and the 2nd floor is very cool.
I looked behind the knee walls and the insulation looks pretty old and poorly installed as it is falling out.
I read the dept of energy guide for insulating a knee wall but was hoping to get some real world advice or maybe even some pics.
I do have a 2nd floor bath room with pipes in the knee wall so I want to make sure they are safe for winter.
jordan83 is offline   Reply With Quote
Old 09-30-2010, 02:37 AM   #2
Rewards Points: 1,092
OK, what is your question? Type of insulation, how to install, or ???
Old 09-30-2010, 04:13 PM   #3
Jordan83
I wanted to know the type and how to install to make sure to leave room for air flow.
Old 09-30-2010, 04:48 PM   #4
Registered User
Rewards Points: 5,256
“Room for air” --------- not in or on the insulation. Not over or under the knee wall, other than the baffles above. Moving air only in the attic space, cover the wall insulation with foam board or house wrap to protect it from wind-washing. Run the foam tight to the baffles above the wall and in the joist space below the wall. Seal all joints. http://www.nrel.gov/docs/fy00osti/26450.pdf
http://www.homeenergy.org/archive/he...95/950309.html
Use anything but low density fiberglass batts which have a convective loop and poor performance.
Gary
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 09:36 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Building knee wall in basement, best approach? RyanD Building & Construction 6 07-04-2009 02:07 PM
L shaped knee wall rootpass Carpentry 6 06-02-2009 11:03 PM
no insulation behind wall boddah Remodeling 1 03-25-2008 04:11 PM
