Knee Wall Acess Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2007, 11:23 AM   #1
Home owner
Knee wall acess door
1st post here...
I recently finished rocking and painting the upstairs of my cape to make a playroom for the kids and a den.
Here's the problem:
There is a 4ft knee wall down both side of the room. Plenty of storage behind.
There was a 48"X48" access panel in the playroom side of the upstairs. I wanted to keep the opening that big to easily store large items.
Now, the room is painted, carpet is coming in two weeks. I need to close the opening with a door, but I want to make it string enought to handle the kids, and lockable.
I was thinking of using bi-fold closet doors cut to height, or making one big panel on hinges to open into the room.
Any suggestions?? I can post pics if needed.
Thanks in advance.
Dan N is offline   Reply With Quote
Old 01-11-2007, 11:28 AM   #2
you could do that Gluing it to a sheet of 1/4" Veneer ply to make it look good......
mdlbldrmatt135 is offline   Reply With Quote
Old 01-11-2007, 08:58 PM   #3
I've done this many times.
For best appearance, do this.
Get a pre-hung hollow core door, not bored for lockset.
Cut the door, Cut the jamb 1 1/4 longer than the door to allow for
carpeting, plug the bottom of the door, buy a cheap door boring set,
hang and case the door, bore for lockset, mortise for strike-plate,
install keyed lockset to keep the kids out.
You'll probably be out less than $100.00 if you buy a cheap door.
It's not as difficult as it sounds...usually takes about 2 hours
jbob is offline   Reply With Quote
Old 01-12-2007, 10:13 AM   #4
Home owner
I was considering a pre-hung door, but a 48 inch door is kinda big. That's a big swing to open the door. I think I might go with 2 24" peices of sanded hardwood and installing inside, "european" style hinges.Actually the opening is 47" wide.
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 10:14 AM
knee wall question jscholl411 Building & Construction 7 10-10-2007 01:30 PM
Knee wall door? luner99 Carpentry 5 04-09-2007 09:06 PM
Knee wall access door... luner99 General DIY Discussions 2 02-26-2007 01:31 PM
