Knee/Pony Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2007, 06:06 PM   #1
Rewards Points: 790
Knee/Pony Wall
As you go upstairs into my finished attic space (currently unfinished) I would like to build a knee wall that will act as a railing on one side. My question is how should I attach this. I have heard that I can attach the posts to the floor joists, but the wall that I will be constructing with run parallel to the joists. How can I strengthen the wall and what height should it be?
cibula11 is offline   Reply With Quote
Old 01-23-2007, 09:43 AM   #2
Rewards Points: 790
Just wondering how I can give added support to a knee wall. I don't want it to be wobbly. One side will attach to the wall and the other will jut out and not be attached to anything. I don't really want to have to build a post that extends to the ceiling as I am trying to keep the space as open as possible.
Old 01-23-2007, 05:01 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As mentioned, attach your 4x4 posts to the floor joists, make sure that you lag bolt them. You can also attach the ends of the wall to the ceiling structure to create greater stability.
Additional ways to create strength and stability for a half wall:
Use long screws to assemble instead of nails.
Double up all bottom and top plates.
Double up end studs.
Make sure that you overlap doubled studs and plates.
You can sandwich sheets of plywood over the half wall.
Use 5/8" Sheetrock over it.
Use 'L' and 'T' brackets to 'lock' connection areas.
- Build Well -
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
