KNEE/HALF Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 09:30 PM   #1
KNEE/HALF wall
Hello all..built s knee wall 42" high and the end that is free standing is a bit to wobbly for me..there is a cocrete slab underneath...any ideas as how to anchor it to stop the movement??????????
mikebmore is offline   Reply With Quote
Old 11-26-2008, 09:35 PM   #2
A piece of threaded rod epoxied into the concrete running through the top and bottom plate with nut and washer at the top. The wall will stiffen up when you drywall it, though. A sheet of plywood would also stiffen it up a lot. Is anything going up against it?
jerryh3 is offline   Reply With Quote
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
