Old 09-03-2006, 08:10 PM   #1
Kitchen shelving
I want to hang some shelving in our kitchen, on tiled walls, but have a couple of questions before I start. When I run the electronic stud finder over the tile, it gives me what seem to be strange readings. Will a stud finder function reliably on tile?
When I find the studs, I assume I'm going to drill holes in the tile for the screws but what kind of a bit should I use for drilling the holes?
Quarterinch is offline   Reply With Quote
Old 09-04-2006, 04:03 PM   #2
Master Craftsman
Big Dave's Avatar
Kitchen shelving
I never use a stud finder as they are usually unreliable. The best bet is to measure off of a receptacle which should be nailed to a stud. A masonry bit will penetrate wall tile. There was a trick to keep it from walking but can't remember what it was. I think if you put a peice of tape on first then start your bit on it, it won't walk. Be carefull when tightening up the screws so as not to pop the tile loose from the wall.
My suggestion if possible would be to make a free standing shelf that sits on the floor.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 08:13 PM
