Kitchen Remodel - Header/framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2008, 12:28 PM   #1
banging thumbs
Kitchen Remodel - Header/framing question
Hello,
We are planning our kitchen remodel and are looking to gain a better understanding of the framing required.
As part of the reno, we want to move the door over a few inches, frame out a new window, replace/reframe the old window for a smaller window. I'm guessing there is no header over the existing window (see picture), so my question is, would we run a single header spanning the width of the room or would smaller headers/and jack studs be needed for each opening?
I've attached a couple images showing the idea. Please ignore the mistakes in the framing illustration. I was doing it quickly and no measurements were used. I just want to understand the header for this type of reno.
Thanks.
bakerhouse is offline   Reply With Quote
Old 04-04-2008, 09:21 PM   #2
remodeling pro
Since the entire width of the room appears to be somewhere in the 10' range, and the sketch seems like you want to keep all of the tops in line, I would span it with one header, then frame the individual rough opening under the header. It will be much easier to keep the wall straight.
The window most likely has a 2 x 6 header packed tight to the top plates.
troubleseeker is offline   Reply With Quote
Old 04-04-2008, 11:20 PM   #3
banging thumbs
The width of the room is about 9' 7". There's no second floor, just a crawl attic space. My next issue is the header size, will a 2x12 sandwich with 1/2 plywood be okay for this distance?
Thanks for the response.
Old 04-05-2008, 07:34 AM   #4
you have the right ideal and thar should be plenty for the size of the room and the weight it would carry
clasact is offline   Reply With Quote
Arching an exterior wall in Kitchen Question Tristar Carpentry 1 03-26-2008 05:31 AM
Conquering a Kitchen Remodel skip97 Remodeling 2 02-27-2008 07:54 PM
Game: Remodel my kitchen! hubbard53 Interior Decorating 9 11-19-2007 07:38 AM
Kitchen Remodel - 101 allen1466 Remodeling 5 06-22-2007 08:56 AM
Kitchen remodel frank551 Electrical 2 11-15-2005 07:13 PM
