Closed Thread
Old 01-27-2008, 11:40 PM   #1
Default kitchen door pella vs. jeld-wen
Hi All,
We are currently remodeling our kitchen and would like to replace a door.
I called Pella yesterday and they said for a 2'-8" x 6'-6-1/2" door it will probably cost around $2,600! This is from their Designer Series. The door that I want is just a single lite double glazed Low-E door. Nothing fancy...
Well, the hubby went ballistic when he heard the price so we drove out to your ever reliable Home Depot! We asked the "very helpful" gentleman to give us an estimate. He offered a Jeld-Wen door. After punching in the some info. (size, etc.) in his computer it came out with a price...drum roll...$500.00!!!
I was shocked! Can it be that much of a difference between the two? What gives? Is it the quality? Am I setting myself up for future problems if we go with a Home Depot product?
Same size, same single lite, low-e glazing, both came pre-hung....
Anyone have any thoughts?
Thanks!
ccalmonte is offline
Old 01-28-2008, 12:23 AM   #2
My wife and I have been looking at Jeld-Wen from HD for our dining room. (Pre hung french) We have not made a purchase yet but I know from HD and Lowes (same products, Lowes is $1 cheeper) that price of $500 is because they order in bulk and the savings is reflected to us the consumer. I found this out because we were looking for an outswing, they stock inswing. That same door for $500 if ordered in outswing was over $900 because the outswing was not part of their bulk orders only inswing. So you $500 door might actually be a $900 door.
another point to check, the jeld wen is probably steel the other may have been a vinyl, wood or combo. The energy star ratings of the jeld wens are actually really good. when comparing then to a similar pella for $900 at HD the Jeld wen rated better.
Personally, I am going to get the jeld wen, for $500 its worth it. if its crap it will get replaced if not I saved a bundle. You can get crap for 2k too.
mgarfield is offline
Old 01-28-2008, 12:27 AM   #3
Oh... I have also noticed that a lot of home improvement shows are going with Jeld wen too, not that this means ANYTHING, it most likely means Jeld wen paid them, but I thought it was interesting
Old 01-28-2008, 05:47 PM   #4
Windows & Remodeling
HomeSealed's Avatar
What are the two doors made of? For $2600 that sounds like a wood door including installation or at least fiberglass. How about the jeld-wen, it would definitely be a junk door if that price includes installation . Thats not to say that jeld-wen doesn't make some nice products, but a $150 steel door plus installation($350) will be rusting out in 5 yrs. I would highly recommend a fiberglass product if you haven't decided on material yet.
www.HomeSealed.com
HomeSealed is offline
Old 01-28-2008, 06:31 PM   #5
Remodeling Contractor
oldfrt's Avatar
Originally Posted by ccalmonte View Post
Hi All,
Thanks!
You've stated the size of the door to be 2'-8" x 6'-6-1/2".
In most product lines I am familiar with,this is a custom sized door,(with a 6'8" door being the norm.
Double check your height before ordering any door and double check the pricing. A custom sized door will usually run a bit higher than the standard.
Once you order the door ,you own it.
If a 2'8" x 6'8" can be installed in the opening(check the distance above door to ceiling,taking into account the header)the price will be less.
Personally,I'd go with a fiberglass door,like Therma -Tru for durability and medium pricing.
oldfrt is offline
Old 01-29-2008, 08:37 PM   #6
Thanks to all who replied...much appreciated!
I think we are going with the Jeld-Wen from Home Depot. We re-measured and it is 2'-8"x6'-8" door so it should be a standard size. I think the Jeld-Wen is a steel door, primed and pre-hung.
HomeSealed, he estimate that we got does not include installation. Its just the door. I think Pella's Designer Series is wood and clad in aluminum. The $2,600 does not include installation.
Old 01-29-2008, 08:56 PM   #7
HomeSealed's Avatar
Well the Pella being wood does explain the price to some extent, but it is still pretty high. I really would strongly recommend pricing a fiberglass door (may be pretty close to the $500) but the steel may work out fine.
www.HomeSealed.com
Old 02-27-2008, 01:57 PM   #8
window and door guy
The Designer Series are usally fitted so you can get blinds in them ,did you ask about their Architect or Pro-Line , they are a bit cheaper .
stevenc is offline
Old 04-11-2008, 01:51 PM   #9
Smile response
Be careful, most door manufacturers market and produce multiple level products. The Pella Designer Series is a high end good quality door system. I don't know what Jeld Wen product you are refering to, but if it's only $600.00, it's probably a steel door with a wood jamb. Like comparing apples to oranges. Good luck,
Hi All,
Thanks!
usherboy is offline
Old 04-28-2008, 09:16 PM   #10
Very very important to remember when you're dealing with Pella Vs Home Depot (aka Jeld-Wen) you are dealing with Pella trained professionals. A door for $600 from Jeld-Wen is definitely not an installed price!
The Designer series is very high end and includes a 3rd pane of glass. You also have the option of adding low E glazing to this pane. Also if you are a buying the door without installation, whether you are paying a contractor or not make sure you talk to a Pella Trade Rep. If you are buying the door directly you are acting as your own General Contractor.
Also ask yourself if you have a problem with a Jeld-Wen door you bought at Home Depot does HD come out and fix it?
I know that Pella Does... Though sometimes, especially in the peak building season they might a tad bit slow, but they will come out and fix it.
MOST IMPORTANTLY! No matter who does the work for you, it is your responsibility to make sure your contractor installs the product according to the manufacturers requirements, it they only way in most states that the door meets building code now-a-days, and it your likely to have warranty issues if the problem can be rooted to improper installation! None of the major brand window manufacturers honor a warranty on an improperly installed window.
So, if Pella does the work, they own the installation for the warranty period.
WindowGeek is offline
Old 05-19-2008, 08:37 PM   #11
creative designer
Wow, what a price difference!
I was going to add that the price was probably not including installation, but others have already done so...
What interested me most is the comment on warranties and such. If the door costs 2,000+ but includes a good warranty, it might be worth the extra money - you know that future repairs will be taken care of. If you're in an area where weather isn't as much of an issue, then maybe the warranty won't be worth it for you.
Which door did you decide on (if any) so far?
AliceM is offline
Old 05-20-2008, 12:26 PM   #12
You get what you pay for mostly. There is no "magic deal" at HD due to "volume" or other such things. It is a retail store, where you pay retail prices for things. Often they wrangle "special models" from their vendors which are cored-out versions of the real thing, and these cored-out products can be put on "SALE" at much lower prices than the real deal sold somewhere else. (The mattress industry pioneered this nonsense 50 years ago.)
Just as a bet, I would bet the $600 door at HD is a "different animal" than the $2600 door from Pella. I'm not advocating one or the other, but just saying they are going to be substantially different items, and each may be a terrible, good or great value on their own merits, at their respective price points. A Mercedes is a good thing, and a Ford is a good thing, but they are not the SAME thing.
redwood99 is offline
Old 11-06-2009, 06:24 PM   #13
Don't buy Jeld-Wen!! I bought an exterior patio Jeldwen door. It leaks, and has ruined my carpet. The Jeldwen rep came out and said they don't guarantee against bad weather!? Neither Jeldwen or Home Depot will make it right.
chris M. is offline
Old 11-06-2009, 06:46 PM   #14
Extreme DIY Homeowner
Scuba_Dave's Avatar
Please do not dig up old threads just to complain
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is offline
Closed Thread
More On This Topic
This word is wen. Is also the fourth tone. Wen. Wen. Means to ask. To ask for something. And we can write this word in this way. One. Two. Three. Actually this part is another word which means the door. The door. But when we put another part inside, it... Read More »
If you have old, aluminum frame windows in your home, you might be feeling the winter chill more severely. Swap out your windows for more modern ones and enjoy a cozy winter. Read on to learn more. Read More »
One area where homes are less energy efficient is around doors. Many older doors leak around their edges, and many others are simply not insulated enough to provide good energy efficiency. Making doors energy efficient is one of the most obvious ways to... Read More »
You have a beautiful fireplace in your home and you want it to look its best. A nice set of glass fireplace doors can really class up your fireplace. Whether you want to spend a lot or a little, you can find a nice set of glass fireplace doors easily. Read More »
A wine cellar give you a place to store valuable wines and spirits, and can enhance the value of your home by giving it an elegant upgrade. One of the most important features of any wine cellar is its door. Read More »
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 10:31 PM
Need new kitchen, how should I look for. help. gante Remodeling 2 01-19-2008 05:10 PM
Bath entrance inside kitchen area rich121 General Discussion 1 12-16-2007 07:44 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 05:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-19-2006 12:23 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
