Kitchen Cabinets -Birch Or Oak? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 06:38 AM   #1
Rewards Points: 169
Kitchen Cabinets -Birch or Oak?
I'm doing a complete kitchen reno and am making new cabinets. These will be painted white.
Is one type of wood easier to paint than the other?
RCGA is offline   Reply With Quote
Old 03-17-2013, 07:07 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Oak is typically NOT a good wood for painting. It's grain size is too deep, requiring a lot of sanding, filling and priming for good paint results.
hyunelan2 is offline   Reply With Quote
Old 03-17-2013, 07:13 AM   #3
DIY staff
Rewards Points: 7,174
Yep--oak is not the best choice for paint---
Birch---soft or hard maple ---poplar--would be better choices.
Make some phone calls to hardwood suppliers----you may save a lot over buying wood from a lumber store----
Your location might get you some suggestions from members in your area---
Old 03-17-2013, 07:17 AM   #4
Rewards Points: 169
Thanks.
I'll be buying the doors at a "discount" type lumber store and there only two options - either birch or oak.
My only experience is with oak doors, but my parents stained them.
Old 03-17-2013, 07:24 AM   #5
DIY staff
Good move---making the doors often costs more than buying them already made----
For the face frames and other cabinet parts, any of the woods that I mentioned will work well---
Good luck---many of our members have good cabinet making skills---If you need any help or suggestions ---ask away----
Old 03-17-2013, 08:15 AM   #6
Rewards Points: 790
Since you're asking about birch or oak, I am thinking you want to use plywood to make the doors? If you paint these, you will not see any of the grain. Might as well use cheaper veneer such as luan or paint grade ply. One way is to use very thin paint, used to be called pickling, and finish with urethane coat. Am not a fan of this finish, because I always think they look half done.
If using plywood, you have to look for flat plywood out of the store. You can't make flat doors out of curved plywood that was shelved wrong. You may have to visit several lumber yards, not the big box stores.
carpdad is offline   Reply With Quote
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 07:22 PM
Wrong Paint on Kitchen Cabinets? cbarker Painting 6 02-24-2012 02:53 PM
Are Kitchen Cabinets Secure richard7994 General DIY Discussions 6 11-06-2011 06:21 PM
kitchen cabinets gramnanc Painting 1 10-25-2011 09:02 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 06:31 AM
