Kitchen Cabinet Crown Molding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 09:07 PM   #1
I am considering adding crown molding to my kitchen cabinets. Currently, the distance between the top of the cabinets and the ceiling is 12.5" which seems like a lot to me. Is that too much? What is optimal?
I am looking to do a two piece, perhaps two tone molding.
Any thoughts?
stubits is offline   Reply With Quote
Old 04-09-2010, 09:24 PM   #2
Rewards Points: 5,336
What does the distance above the cabinets have to do with your molding choice? The size of the molding would be based on the room size.
I'll make a assumption that the molding matches the cabinet finish? If that's the case you would either attach it to the cabinet top or you would have applied a matching soffit cover and applied the molding to the soffit/ceiling interface.
Ron
Old 04-09-2010, 09:32 PM   #3
Thanks Ron.
The room isn't very large, just about 100 sq. ft., 10x10.
The cabinets are frameless, so my thinking was to install a nailer strip along the top of them. As I mentioned, I am thinking of doing a two tone, the cabinets are a very light color, but the room has darker brown accents, so the thought would be to install a dark vertical trim piece and then install a lighter crown molding to match the cabinets.
Ultimately, and perhaps obviously, we'd like the molding to reach the ceiling, hence I thought the distance between the cabinet and the ceiling might be important.
Old 04-09-2010, 09:56 PM   #4
Whenever I've had a soffit of, 12"+/- with a crown molding, I've either installed a soffit cover that matched the cabinets with the matching crown or the soffit was painted and the crown was also painted.
It's just a personal choice. You just want to make sure the crown molding is in proportion to the space. If the setup you choose doesn't work for you visually after it's up a while, you can always make an adjustment. Painting would be the easiest modification.
Ron
Old 04-10-2010, 07:15 AM   #5
DIY staff
Rewards Points: 7,174
Hi there,Go next door to contractor Talk and look at carpentry Picture Post------
My Solution to Cabinet Soffets - Contractor Talk - Professional Construction and Remodeling Forum
Something there might give you an inspiration--Mike--
Old 04-10-2010, 05:04 PM   #6
Thanks Mike, that's a pretty nice look!
So, for a small room, 100 sq ft, what is a good size crown molding height?
Old 04-10-2010, 09:44 PM   #7
DIY staff
3 1/2? Buy some samples and a roll of double faced tape. Put them up and see.
Cabinet Crown Molding highchile Carpentry 1 02-24-2010 03:49 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
Kitchen crown molding eroley Carpentry 5 12-04-2008 09:24 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Crown Molding in the Kitchen Woody730 Remodeling 8 05-21-2008 06:17 AM
