Kitchen Backsplash Separates From Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 07:20 PM   #1
Kitchen backsplash separates from exterior wall
Good day all. every year in Jan/Feb when it's very cold, the above happens to approx 1/4 inch gap. When it warms up,it's back flush. Same thing happens to my neighbor's EAST WALL.??
DOES ANYONE HAVE ANY IDEAS??
I can see the vapour barrier & house wrap below the bottom edge of the window frame with the trim off. Many thanx
Colt45 is offline   Reply With Quote
Old 12-11-2011, 07:47 PM   #2
joed's Avatar
Rewards Points: 11,572
Pictures would help. It sort of sounds like truss uplift.
http://www.buildingscience.com/docum...truss%20uplift
Old 12-12-2011, 04:47 AM   #3
Thanx for your reply. I am quite familiar with truss uplift..thank god for crown molding! I find it strange that 2 houses have the same issue on the same exposure wall.
I guess it is best to caulk when the gap is at it's widest??
Old 12-12-2011, 04:39 PM   #4
Rewards Points: 5,336
How do you see the vapor barrier and house wrap under the window? Isn't it sealed?
How does a roof truss move a backsplash away from a wall?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Colt45 (12-12-2011)
Old 12-12-2011, 06:20 PM   #5
joed's Avatar
If it's a gable end or interior wall, truss uplift could pull the truss up. If the top of the wall is fasten to the truss the entire wall could lift leaving a gap where the cabinet & counter stays on the floor.
The Following User Says Thank You to joed For This Useful Post:
Colt45 (12-12-2011)
Old 12-12-2011, 11:37 PM   #6
remodeling pro
I don't think this is it, for two reasons. Primarily, the separation described in not a vertical movement at the countertop, but horizontal between the wall and backsplash. Second, even if truss uplift were vertically lifting the entire wall(which I just don't see happening), the cabinets would rise with the wall, as they are screwed into the studs; so if a gap were to appear from this, it would be at the floor level.
I have a similiar event in my personal house, which is raised pier construction. I am convincedit is due to floor joist movement, because it correlates to how dry or rainy a period we are in. Just another theory
troubleseeker is offline   Reply With Quote
The Following 2 Users Say Thank You to troubleseeker For This Useful Post:
Colt45 (12-13-2011), Ron6519 (12-13-2011)
Old 12-13-2011, 05:29 AM   #7
Thanx, it is horizontal vs vertical movement. I think is a stud moisture broblem. House is 17 yrs old. Strange that neighbor has same problem on South exposure wall also.
Tiling Kitchen backsplash - how to deal with this end? TNSLB Kitchen & Bath Remodeling 1 08-30-2011 05:23 PM
removal of laminate kitchen backsplash kjeffer Building & Construction 2 08-23-2011 09:48 AM
Kitchen Countertop Backsplash Problem tarheelblue Kitchen & Bath Remodeling 7 04-29-2011 05:06 PM
Remove kitchen backsplash? mindysand Remodeling 2 03-20-2011 01:42 PM
Tiling kitchen backsplash deeaa Building & Construction 6 07-17-2008 09:44 PM
