Kitchen Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2008, 06:45 AM   #1
Kitchen Addition
My wife and I are in the middle of a kitchen remodel and I have a couple of questions about lam beam installation/options.
We are installing two new beams to open our kitchen up. Approx will be 24x24 which will have a small hearth room area in this new arera.
One beam will hold the ceiling joists of the kitchen and one beam will hold the roof rafters.
The ceiling joist beam is no big deal however the roof beam is where we a running into questions. The new beam 5 1/4x 13 7/8 if installed under the top plates will push it below the ceiling line and be visible from below.
What options do I have to install this differently to keep it up in the attic above?
Please see attached pics
Kitchen Addition-kitchen-remodel-attic-1.jpg   Kitchen Addition-kitchen-remodel-attic-2.jpg   Kitchen Addition-kitchen-remodel-below-3.jpg   Kitchen Addition-kitchen-remodel-below-4.jpg
handyman2 is offline   Reply With Quote
Old 10-07-2008, 09:40 AM   #2
Registered User
Termite's Avatar
My suggestion would be to explore the options of a different beam. Sometimes you can simply go with additional thickness and less depth, although it depends greatly upon the span and the imposed loads. Another option that is commonly used is to add 1/2" steel flitch plates bolted in the middle of the plies of LVL or on either side. Yet another option is a steel beam instead of an engineered wood beam.
Unfortunately, we can't size the beams for you, as it requires a thorough analysis of the structure and the imposed loads. My suggestion is to hire a structural engineer to come out and determine what will work best for you. Engineers usually charge between $300 and $500 for a one-time consultation and stamped prescriptive letter. You can call your local Homebuilders Association (HBA) and they often have engineers that are members that they can recommend.
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
1000 square foot addition and kitchen remodel.. kemerick Project Showcase 6 08-06-2008 11:33 AM
Kitchen addition rwwood Building & Construction 2 10-29-2007 08:51 AM
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 03:24 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
