King Stud, Jack Stud Holes .. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 11:49 AM   #1
Rewards Points: 149
king stud, jack stud holes ..
Hello and thanks,
I am guessing I know the answer to this question but wanted to throw it out here for confirmation.
We are turning a window into french doors.
Engineer has asked for a 4x10 header which we have installed.
We now have to reroute some electrical and here is my question.
We have to run the existing romex up and over the door to continue the path from the existing outlets to each another..
This would involve a small 1/2 inch hole drilled through the studs in the sapce above the new 4x10 header ..
Is there a problem with doing this at all? Or better yet, is there a distance I would need to be from the end of each stud where the hole would go?
Thanks for any info
beachfront71 is offline   Reply With Quote
Old 04-22-2012, 12:04 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
all holes are to be drilled in the center width of stud and maybe 4 or 5 inches up from the top of the header
hand drive is offline   Reply With Quote
Old 04-22-2012, 12:13 PM   #3
Rewards Points: 149
Added Picture .. The red line is the new path the romex would take to connect outlets ... the old path ran straight across below the window...
You can see there are som new studs that would need a hole drilled for the romex .. albeit small
Old 04-22-2012, 12:27 PM   #4
Rewards Points: 13,216
Not going to be an issue.
Old 04-22-2012, 12:31 PM   #5
Rewards Points: 149
Thanks,
I assumed that was the answer but this will get inspected and wanted to confirm it.
Old 04-22-2012, 12:38 PM   #6
AHH, SPANS!!!
^ yep,for hole placement just split the distance between underside of top plate and top of header and stay in the center most portion of the stud, it will be fine
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 11:31 AM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 02:05 PM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 09:24 PM
