Old 02-10-2011, 09:06 PM   #1
Kids Fort/Playhouse..help please
Ok basically I want to build a 6'X6' fort/playhouse...slide, ladder, etc. My question is based on how to set the foundation and posts for this. I kind of like the idea of NOT burying the posts due to ground moisture, etc. The deck for this will be about 5 feet off the ground. This is not going to have to support a ton of weight, probably 4-5 small kids at a time maybe, but I will also be putting a roof on it. I basically want to use four 4X4 posts on the corners to a height of about 10'. My idea is this: I know that they make these pyramid shaped preformed concrete blocks that will accomodate a 4X4 post (does the post actually bolt to the block?). What if I get 4 of these, get them level and put my posts in them without actually digging down and pouring a footing? Like I said, I'm not sure if I should be overly concerned about settling or not, given the fact that it's not going to support much weight. To give the structure lateral support, I thought I would concrete a 4X4 post into the ground at each corner, leaving a foot or so sticking up, and then attach diagonal braces from these posts to the fort. Yeah I said I didn't want to bury posts, but if these did rot, they'd be simple to replace vs those of the actual fort. Thanks..
jod78 is offline   Reply With Quote
Rubber mulch Vs. Kids Carpet mulch for backyard play system whataboutj Landscaping & Lawn Care 1 04-26-2010 11:22 AM
Need Veg Garden ideas for kids at a hospital Leah Frances Gardening Forum 2 04-21-2010 12:39 PM
Need Help With Space Themed Kid's Room limitdiy Interior Decorating 9 08-14-2009 02:04 PM
Got kids? Little, impressionable kids? mt232 General Discussion 3 11-14-2007 03:58 PM
Kid's Playhouse Vergil Building & Construction 2 06-29-2006 06:54 AM
