Keyless Door Lock? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 01:28 PM   #1
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Keyless Door Lock?
I am looking for a keyless door lock for a friends interior door that does not require screws in the door face as does a conventional barrel bolt.
I remember seeing a door lock similar to the illustration, in shiny brass plated steel. When the door is closed the hinged portion is swung 90
where when it contacts the door face it drops down slightly to latch in position and preventing the door from opening.
To open the door the latch is lifted slightly and swung out of the way. Does anybody know where I can get one of these?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-10-2010, 08:59 PM   #2
remodeling pro
I believe I've seen similiar at Home Depot, in the section by the replacement strike plates, bifold door hdwr,sliding glass door handle replacements, etc.
But I think they were just a stand alone add on, not something that replaced the strike plate.
troubleseeker is offline   Reply With Quote
The Following User Says Thank You to troubleseeker For This Useful Post:
PaliBob (04-11-2010)
Old 04-10-2010, 10:03 PM   #3
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
hayewe farm is offline   Reply With Quote
The Following User Says Thank You to hayewe farm For This Useful Post:
Old 04-11-2010, 01:16 PM   #4
Tool Geek
PaliBob's Avatar
Originally Posted by hayewe farm View Post
Thanks for the Link, Troubleseeker has a good memory. My own memory was not so good as I thought they were part of a lock strike, but now that I see one, I realize that rather than being a lock strike, it is a separate latch that mounts on the jamb up higher so that little playing hands cannot accidentally lock themselves in.
The latch is designed so that it can be mounted on the inside of a RH or LH door. The package includes two #6 x3/4 flat head mounting screws and one very small and short anti-Lock out #1 round head threaded screw. If the door opening direction was reversed the screw would be in the other hole, but then it is easy to remember. The screw always goes in the bottom hole, with the head in the direction shown.
Thanks again,
Disclaimer
& Stay Safe
.....Bob Lavery
Keyless Fixtures...What to do with ground wire? Driven2race Electrical 7 01-17-2010 09:38 AM
Bosch keyless, self locking chuck Bluwolf Tools 1 12-28-2009 06:40 AM
Keyed or Keyless chuck? Ultrarunner2017 Tools 4 12-27-2008 06:46 AM
