Keep Old Tall Baseboard Or Get New Shorter Ones? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2015, 03:01 PM   #1
Rewards Points: 424
Keep old tall baseboard or get new shorter ones?
I need to tear down a wall and this is the baseboard that comes with it. Should I save it or should I get the new smaller ones? Are there any advantages/disadvantages to the newer smaller baseboards?
ghary is offline   Reply With Quote
Old 08-27-2015, 03:18 PM   #2
Rewards Points: 5,336
The decision is up to you. Personal preference. The issue is, will those baseboards come off in one piece? The older wood is nailed with 3" nails and very brittle.. Very hard to remove to salvage and re-install.
Ron
B. Franklin 1759
Old 08-27-2015, 05:21 PM   #3
Rewards Points: 424
yes, it is in one piece, slightly less than 10 feet across.
Old 08-27-2015, 10:20 PM   #4
Rewards Points: 296
It is definitely personal preference. I have torn out plenty of it and reinstalled and as far as I am concerned it's pretty simple, just need to take your time removing it. Also depending on the age of the house the wood it's made out of can be valuable. If you lived in my town and didn't want it I would come remove it for you for free as long as I got to keep the material.
KC_Jones is offline   Reply With Quote
The Following User Says Thank You to KC_Jones For This Useful Post:
mae-ling (08-28-2015)
Old 08-28-2015, 09:05 AM   #5
Rewards Points: 424
I don't understand, why would the wood might be valuable?
Old 08-28-2015, 10:23 AM   #6
Rewards Points: 296
It depends upon the age of the house. My house is over 100 years old and ALL the wood in it is old growth and for the sake of argument it's irreplaceable. The only way I am aware to get the old growth wood is through companies that reclaim the old lumber re-mill and then resell it back to people doing restorations or people that like the look of the old wood (yes old growth looks a lot different in some cases). If you ever price out what that wood is sold for you would realize how valuable it is. When I watch remodeling shows on TV and see them ripping out some of that stuff and throwing it away it almost brings a tear to my eye. I really laugh when I see people ripping floors out and putting down new floors. Essentially they rip out say a $10,000.00 floor and "upgrade" to a $3000.00 floor. It's a case of people don't know what they don't know.
Old 08-28-2015, 05:32 PM   #7
Rewards Points: 3,719
I like the BB to be the same throughout the house. Chances are the plaster does not go down low enough to use modern base. They used to nail a 1x6 to the studs behind the base and plaster above that.
If you can find anyone selling that the price may shock you. If you can find a mill shop with the right blades the cost may amaze you. If they have to make the blades to mill it the cost will kill you.
It can be carefully removed, the nail pulled from the back side and reused with no problem. I have actually gone so far as to cut plugs to fit where an outlet used to be and won't be on a new install.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 08-28-2015, 08:43 PM   #8
Rewards Points: 948
I like the old base--do you know how much base that size would cost today? You're crazy to remove it. Most base being installed today is mdf or plastic--if you have base like that, keep it.
If you want a modern aesthetic, you don't install base at all. Modern isn't narrow base, it's no base. A truly modern look costs a lot of money because it relies on good craftsmanship--not on trim to cover mistakes. Builders use cheap base because the cost of being careful is greater.
keymaster is offline   Reply With Quote
Baseboard. A Big Deal Question! altc81 Flooring 15 11-03-2013 04:00 PM
Rotted Baseboard miamicuse Carpentry 11 09-08-2013 10:09 AM
how to replace baseboard radiator with a shorter radiator 1needhelp Plumbing 1 08-19-2011 08:13 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
