Just A Wall! - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 11:23 PM   #16
Rewards Points: 978
bottom line is, this wall is not load bearing. going to f*cking tear it down this weekend
federer is offline   Reply With Quote
Old 12-19-2012, 12:51 AM   #17
DIY staff
Rewards Points: 7,174
I don't think that is load bearing---the 12" extension was added many years after the original framing---
Your pictures were to close up for me to see what it would be holding up---
federer (12-19-2012)
Old 12-19-2012, 07:51 AM   #18
Rewards Points: 978
let me take a pic for you mike. thanks
Old 12-19-2012, 08:02 AM   #19
Rewards Points: 978
this is what it looks like above the 'header"
Old 12-19-2012, 08:05 AM   #20
Rewards Points: 978
this is other side , closest to exterior wall
Old 12-19-2012, 10:17 AM   #21
Rewards Points: 2,212
Once again your not going to like my answer - This is the same type of question you asked before. Yes I have my guess and that is all any of us can do with a few pics on the interwebs. Like others I did reno work for years and have found that not every situation follows the proper load bearing 'rules', especially when you get into older houses.
So my advice . . . "Get someone in to look at it" if not an SE then a carpenter experienced in older home renovations.
Yes there are guys on here who will guess that it isn't load bearing. They might be right and they might be wrong. It has happened before. There was a thread where someone came asking if something was structural, many said have someone look at it, a few said it wasn't. The home owner did have someone look at it, guess what? IT WAS STRUCTURAL!!!!! If he would have just went on the advice of those who said it wasn't he could have caused serious problems.
mae-ling is offline   Reply With Quote
The Following 2 Users Say Thank You to mae-ling For This Useful Post:
federer (12-19-2012), oh'mike (12-19-2012)
Old 12-19-2012, 06:45 PM   #22
Registered User
Rewards Points: 526
What is the species/span/size of the joists; are they flat roof rafters- compare for local snow load. Maybe the wall was added afterward for a room separator (partition) or added for a sagging roof... check and compare with/without the wall; (after ceiling joist tables, scroll down) http://publicecodes.cyberregs.com/ic...?bu2=undefined
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 12-19-2012, 07:25 PM   #23
DIY staff
s.
Wise words----very wise.
Old 12-19-2012, 11:25 PM   #24
Rewards Points: 978
hey man! thanks for coming in here. i totaly understand what you mean, i really do. this is why i post on here to get your ideas and opinions. and i really appreciate everything you say because you guys are so honest and no BS.
if you dont mind me just bugging you-from the pictures that show a gap between this wall and the rafters, would you guess that it is thus no load?
Old 12-19-2012, 11:41 PM   #25
I can't even give you a guess. Well I can but I won't.
You really need someone on site to look at it.
Old 12-19-2012, 11:46 PM   #26
Rewards Points: 978
Gary
wow gary! you are the best. honestly, i dont even know what species they are. so the rafters are sistered together. i cant get a good exact length but i want to say the wall was added afterward. because if you take a look at the last picture, the room partition is only about 8ft wide. also this is the part of the house that the previous guy renovated (added on). nothing is original here.
Old 12-19-2012, 11:57 PM   #27
Rewards Points: 978
thanks! we will get a carpenter to take a look. the one we already have out says its fine.
Old 12-22-2012, 06:25 PM   #28
Rewards Points: 978
merry christmas everyone! we decided to get some last minute 'shopping" done. start:
Old 12-22-2012, 06:26 PM   #29
Rewards Points: 978
middle:
Old 12-22-2012, 06:27 PM   #30
Rewards Points: 978
the end!
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
