Jumping Jack Or Plate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 02:55 PM   #1
Rewards Points: 117
Jumping jack or plate?
I live in Houston. Sand and clay under the old deck. Putting down about 200 sq ft of slab.
Having trouble deciding which kind to use. Any thoughts? I dug 8" to get it cleared but plan on 2" of gravel/dirt and 4" of slab.
Any ideas are welcomed.
Dornier is offline   Reply With Quote
Old 04-05-2011, 03:38 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
I have a question, what is "jumoing" and a suggestion, 4" gravel under 4" of washed sand, under your crete.
Andy.
AndyGump is offline   Reply With Quote
Old 04-06-2011, 10:13 AM   #3
Rewards Points: 117
Thanks Andy,
No rebar or mesh?
Old 04-06-2011, 10:16 AM   #4
AndyGump's Avatar
Rewards Points: 666
#3 RE-BAR 24" O.C. both ways.
Andy.
Old 04-06-2011, 10:58 AM   #5
Concrete & Masonry
Rewards Points: 548
Plate compactor without a doubt for your situation.
jomama45 is offline   Reply With Quote
Old 04-06-2011, 07:29 PM   #6
Rewards Points: 117
Yeah I found a plate rental.
Someone experienced will pour for me, but I'm doing the form myself.
1. Is it necessary to drill into the house slab for rebar, or can I just use mesh and an expansion joint?
2. Does it matter the concrete type before picking an expansion strip? I have seen the "quickrete joint strips".
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 06:54 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 08:54 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
Phone/Fax Wall Jack cmgith Electrical 5 04-18-2009 11:21 PM
