Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 12:38 PM   #1
Joists
We have an old Key West home (pier construction) with joists that are 2"X 5 1/4"(real size Dade pine)spaced about 24" apart.They are notched to fit the sills about 4 1/2 inches. I would like to add joists between them - they would be 1/2 the width of the house and rest on the center beam. However fitting anything with a 18 inch craw space is a problem without major surgery. I am wondering if I could use a kind of sandwich consisting of a 2x4 at the center and 1x6's on each side.
Any help would be appreciated
DSGG
dsgg is offline   Reply With Quote
Old 12-24-2012, 05:00 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
It sounds like you are not replacing what is there which is a good start.
What ever you do to stiffen up the floor (which is what I assume you are trying to do) will probably not hurt but it may not be all that much help either.
You may want to think about adding some footing pads down the center of each side between the center cripple wall of yourt foundation and the perimeter walls. Then add posts and piers and some pressure treated 4x6 to act as intermediary beams...which they will be. Hmmm...could have said that better.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 12-24-2012, 05:57 PM   #3
Rewards Points: 13,764
I agree with Andy but would use ganged up 2 X 6's instead. less likly to sag, curl or twist.
Old 12-24-2012, 08:24 PM   #4
Thanks, center beam(not sure of exact terminology) is about 10' from each side.I couldn't get anything as long as the house in there but I guess shorter ones could meet over a pier.
Sistering Joists and Adding a Beam Mikeman Building & Construction 6 09-30-2011 08:11 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
