Joist Vs Load Bearing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 11:42 AM   #1
Rewards Points: 97
Joist vs Load Bearing
I had to make a few holes in some ceiling joists. 1 two-inch hole per joist. Across 6 or 7 joists in roughly the same spot. I made sure that I was 2 inches above the ceiling drywall when I made the holes. I realize that the joists are weakened but did I just weaken them to a point of concern?
There are 2 bedrooms above. The joists are 9 inches wide.
edta1 is offline   Reply With Quote
Old 06-02-2011, 12:04 PM   #2
Rewards Points: 2,240
How thick/deep are the joists? - 2 X 10, 2 X 12?
What is the span of the joists?
Post a picture/s.
rossfingal
rossfingal is offline   Reply With Quote
Old 06-02-2011, 01:39 PM   #3
Rewards Points: 97
Post a picture/s.
rossfingal
The joists are about 2x10 and spans about 9 feet. The hole on each joists is on one side-- about 30inches from one end of the joist.
I'll take measurements tonight and draw it out.
Old 06-02-2011, 02:03 PM   #4
SteelToes's Avatar
Rewards Points: 150
I believe as long as holes are drilled a minimum of 2" from the top and bottom of a spanning lumber and no hole exceeding more than 1/3 the width of the lumber you are fine...
SteelToes is offline   Reply With Quote
Old 06-02-2011, 04:37 PM   #5
Yes - as "Mr. Toes" says - you shouldn't have any problem!
No worries Mate!
RF
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
load bearing walls rvesci General DIY Discussions 4 12-28-2010 09:51 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
Sister joist and load bearing wall Daniel048225 Building & Construction 2 09-21-2009 09:33 PM
Load bearing wall removal options ikessky Remodeling 2 08-24-2009 03:18 PM
