Joist Spans- Please Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 07:10 AM   #1
Joist spans- please help
Hello,
I'm building a 15'x15' roof over a patio. I'm using 6"x6"x8' posts and 2-2x8's screwed together for beams. The joist span is 14'. I was told by a local inspector to use 3"x8" s every 16"oc to span that but it seems like alot of weight. I'm worried it will sag over time. Thoughts?
RyanJ is offline   Reply With Quote
Old 09-17-2011, 07:20 AM   #2
Civil Engineer
Rewards Points: 4,782
There must be some confusion about your project. If you are simply building a roof, using 3"x8" lumber for joists makes no sense for a 14 foot span. Not that the weight will cause the joist to sag, it won't, but 3x8 @ 16" OC is dramatic overkill for a simple roof. Either you misunderstood the instructions of the building inspector, or he misunderstood your project, or there is something else going on you have left out, like maybe your roof is supporting earth? I suggest you revisit the inspector with a set of plans and discuss the project again.
Daniel Holzman is online now   Reply With Quote
Old 09-17-2011, 07:20 AM   #3
Rewards Points: 5,336
The building inspector's opinion is the one you need to listen to.
I would have asked about 2x10's for the span.
What sort of roof design is going on this?
Ron
B. Franklin 1759
Old 09-17-2011, 07:28 AM   #4
The roof will have 1/2" plywood with vulkem epoxy and the ceiling will have 1/2" durock. The whole structure is getting covered with durock and plastered. Thanx
Old 09-17-2011, 07:30 AM   #5
And it's non-load bearing, however it is in a hurricane zone.
Old 09-17-2011, 08:02 AM   #6
Framing Contractor
What kind of roof is it...hip roof, gable, shed?
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
Ron6519 (09-17-2011)
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
floor joist spans Gray Building & Construction 6 06-24-2010 08:37 PM
