Joist Span Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 02:33 PM   #1
Rewards Points: 93
Joist span question
I currently have 2x8 24 oc joist for my kitchen floor, a couple of them where cut completly through by the old owner. Im planing on changing the 2 joist and beefing them up, sistering a second 2x8. Im just wondering how much more strenght does this add? The span is 11'8" with 7" both sides sitting on sinder block and beam.
From what I can find online, 2x8 24oc is good for 11' spans (if the info i found is correct). Would the sistering be enough to bring this up to code?
simonb is offline   Reply With Quote
Old 08-28-2011, 03:01 PM   #2
Too Old
If the original joist was cut completly through as you stated then sistering a joist to the cut joist is not adding any extra support. Why not add a couple more joists and get the joists at 12" on center? That would help the strength of the floor being that you are over spanned already.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
The Following User Says Thank You to havalife For This Useful Post:
Marbledust (08-29-2011)
Old 08-28-2011, 05:59 PM   #3
Rewards Points: 93
I first remove the cut joist of course then replace with a double.
Old 08-28-2011, 06:10 PM   #4
I like what simonb said. add new joist and they will be 12'' onc. Also, replace the cut joist like you posted.
If you plan to put tile down your 24" oc will not cut it. In fact 12" oc will only work with ceramic, not natural stone. If you sister them on 12" oc it will work for stone.
I ran your spans thru the calculator on the John Bridges site.
NASCAR9 is offline   Reply With Quote
Old 08-28-2011, 06:19 PM   #5
Rewards Points: 93
I wasnt going to add 12oc, i was going to keep it 24oc and just sister the joists. Can you let direct me to the calculator you used?
Old 08-28-2011, 06:50 PM   #6
Framing Contractor
There's no need to do that.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-28-2011, 08:12 PM   #7
Rewards Points: 93
No need to do what? Replace the cut one? Double up?
I rather replace it when there is a foot missing from the joist.
Old 08-28-2011, 08:15 PM   #8
Rewards Points: 93
Can someone confirm what the span of a 2x8 on 24c is? and maybe point me to a calculator?
Old 08-28-2011, 08:25 PM   #9
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
http://www.awc.org/calculators/span/...rcalcstyle.asp
10'3" for Spf #2
There's also:
http://www.johnbridge.com/vbulletin/deflecto.pl
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-28-2011, 08:29 PM   #10
Framing Contractor
1' of the joist is missing? Still, no need to replace it when you can just nail the double right next to it. Your giving yourself more work for no reason. What harm will the joist cause by staying there?
Joe Carola
Old 08-28-2011, 08:32 PM   #11
I have gas!
Removing it might make it easier to get the new joists in though. It's only about 15 minutes of work with a sawzall.
Old 08-28-2011, 08:34 PM   #12
Rewards Points: 93
Thats exactly it. There is no rim plate and they poored cement between the joists. Taking it out takes me 15 minutes but saves me from having to break all kinds of cement.
Old 08-29-2011, 05:11 AM   #13
Framing Contractor
You have to break cement to put in the second joist anyway.What about when you take out the existing joist, you have to cut every nail from the subfloor into the top of the joists. You will want to secure the subfloor back to the new joists.
Gluing the top of the new joists isn't enough. If you do take out the existing joists, you can get the new one in first and place a 2x4 flat against the top of the new joists (with glue)with the 3-1/2" facing the bottom of the subfloor and the 1-1/2" part against the top of the new joists. Screw through the 3-1/2" part of the 2x4 into the bottom of the subfloor,then ail through the new joist into the 1-1/2" part of the 2x4.
Joe Carola
Old 08-29-2011, 07:08 AM   #14
Rewards Points: 93
They sistered the joist with a 4 foot 2x6 when they built the house. Im not sure why they added the 2x6 because its only about 4 feet long and serves no purpose, its not even glued and nailed/screwed. But either way, removing both of these leaves me with only having to break a small peice of cement. Trust me, this way is easyer hands down.
The room above is my next project, so i will be screwing the flooring into the new joist when the time comes.
Old 08-29-2011, 09:10 AM   #15
Too Old
I guess if you are good with an overspan then do it the way you want. If you want to do it right then add joists to 12"oc a little more work but then you know it's right.
Heavy joist span tables rvr600 Flooring 1 08-04-2011 08:11 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Steel Ceiling joist ttilton Building & Construction 1 08-26-2010 08:26 PM
Joist size and span under tile. jackson_norman Building & Construction 9 08-12-2009 08:10 AM
Maximum span without intermediate support question yaryar Building & Construction 2 11-11-2008 10:08 PM
