Joist Sizing /frame - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2014, 10:54 PM   #1
Rewards Points: 168
joist sizing /frame
Were a lot of the ranch style homes built in the late 70s in the south east built with main joist that were pressure treated, on outside framing ? Also were most of them the 2 by 8 or 2 by 10 for the outer frame?
hidden 1 is offline   Reply With Quote
Old 05-23-2014, 11:06 PM   #2
Msradell's Avatar
Rewards Points: 120
Not quite sure what you're talking about. What you calling the main joist? Normally only the sill plate would be pressure-treated, everything else wouldn't be.
Msradell is offline   Reply With Quote
Old 05-23-2014, 11:22 PM   #3
Rewards Points: 13,250
May help to share why your asking so we can figure out what parts of the house your talking about.
http://www.bing.com/images/search?q=...lectedIndex=10
Old 05-24-2014, 03:47 AM   #4
Rewards Points: 528
Guess it would be the sills .its 1st piece of wood u see on block foundation when in crawlspace looking at outer corner
hidden1 is offline   Reply With Quote
Old 05-24-2014, 09:21 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
not likely pressure treated but regular wood sitting on metal or felt paper to separate concrete/block from wood.
hand drive is offline   Reply With Quote
Old 05-24-2014, 12:01 PM   #6
Rewards Points: 168
ok thanks..Is the rim joist regular untreated wood ?
Also are they mostly 2 by 8 ?
Old 05-24-2014, 07:31 PM   #7
Rewards Points: 206
First piece of wood would normally be pressure treated as it is what touches the concrete. Rim joists do not touch the concrete so they are normally not PT. Ron
ront02769 is offline   Reply With Quote
Old 05-24-2014, 10:13 PM   #8
I've seen many an older home built without a pressure treated sill plate. Some just used an aluminum or galvanized termite shield.
Should be able to look at the wood to see if it's pressure treated, should be a different color.
Rim Joist inaccessible. darklightwarrio Insulation 10 01-13-2014 10:02 PM
Sizing deck joist darren Building & Construction 6 04-22-2012 07:08 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
