Joist Size And Span Under Tile. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 08:43 PM   #1
Joist size and span under tile.
What is the recommended joist span and size of joist for tile floors?
jackson_norman is offline   Reply With Quote
Old 08-07-2009, 12:55 PM   #2
Remodeling Contractor
joist size depends on span and spacing. Together they help determine the deflection factor of the floor. This is what tells you that a floor is sufficient for tile. Post a more detailed question.
Old 08-07-2009, 01:36 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
You can use:
http://www.johnbridge.com/vbulletin/deflecto.pl
or
http://www.awc.org/calculators/span/...rcalcstyle.asp
to calculate deflection.
the general rule of thumb is L/480 for tile, L/720 for stone.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-08-2009, 08:28 PM   #4
Are 2x8 joists acceptable to tile over. Thee is a 5/8" sub-floor and 1/2 " underlayment plus 1/4" Hardy Board between the underlayment and tile. The joists are 16" on center and are 12' long. Will this be ok?
Old 08-09-2009, 11:18 AM   #5
This translates to a deflection of L / 302. you are close but not ideal. I would have removed the 1/2" underlayment and installed 3/4" exterior grade plywood. Hardi board should not be installed over underlayment, since it is installed with thinset and the underlayment does not have water resistant glue. Since the maximum deflection for tile is L / 360, and for natural stone is L / 720, your floor is rated for Sheet Vinyl or wood.
Old 08-09-2009, 12:12 PM   #6
ccarlisle's Avatar
Would doubling up his 2x8's - i.e sistering two together - help here?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-09-2009, 02:07 PM   #7
Hi Bob, My floor as it is at the moment has linoleum covering. It is in bery good shape. Can I use thinset over the linoleum to adhere the Hardy Board to the floor? I can sister a 2x6 to the existing floor joists but it would be a major job as the room beneath the floor is finished off with suspended ceiling. Thanks for the input. Norm
Old 08-10-2009, 04:19 AM   #8
Sistering new joists will help. Blocking will help. Straping (runing a board across all joists will help a lot.) This creates an I-Beam structural floor.
You cannot use thinset over the linoleum. It will not adhere. Remove it and the underlayment.
Old 08-10-2009, 12:32 PM   #9
Thanks Bob for all you help. Greatly appreciated. Norm
Old 08-12-2009, 08:10 AM   #10
Registered User
Termite's Avatar
I moved your thread from the landscaping subforum to where it belongs!
what kind & size floor joists needed to span 15 feet? redss Building & Construction 17 07-11-2009 05:02 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
pole barn ? @ span length & size lumber req.. ugabulldog Building & Construction 3 09-11-2008 01:07 PM
What are the joist requirements for a tile floor? slatergrl Flooring 8 07-16-2008 10:08 AM
correct joist size for attic helpless handyman Building & Construction 1 07-05-2006 11:29 PM
