Joist Repair Sister Method Existing Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 09:23 AM   #1
joist repair sister method existing floor
level of floor off by 2 inches 6 joist's need to bee sisterd in order to get back to level can new sister joist furthest from undamaged joist be offset the 2 inches higher then work back 1 3/4 , 1 1/4 , 3/4 and so on untile i am flush with the undamaged joist
jmccarthy121 is offline   Reply With Quote
Old 07-27-2012, 09:41 AM   #2
Rewards Points: 2,212
If the joists have cracked or sagged, new ones sistered beside will straighten them out.
What size are the existing joists, what span, and how far apart.
Maybe you need additional support under them?
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
CopperClad (07-27-2012)
Old 07-27-2012, 09:42 AM   #3
Hi, welcome to the forum. We will need a little more information in order to help you address your situation. How old is the home? How many floors is the home? What floor of the home are you having issues? What size are your existing joist? Is the floor sagging in the middle or? What is supporting both sides of the joist?
CopperClad is offline   Reply With Quote
Floor joist help jsvedia Flooring 3 03-26-2012 09:18 AM
floor joist repair the proper way jmay Building & Construction 2 03-25-2012 07:09 AM
Subfloor repair Dave321 Flooring 3 09-16-2009 08:59 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Second floor addition over existing 1st floor. handball Building & Construction 1 02-10-2009 01:08 PM
