Old 10-27-2008, 04:56 PM   #1
Joist, rafter, and stud spacing for shed?
I'm going to be building a 12x16 shed in my backyard which will be a non-permanent structure. I am simply going to frame out a platform which will be supported by pressure treated 6x6x8 timbers resting on gravel. This will be a "garden shed" which will house two garden tractors, a push mower, yard tools, and seasonal decorations. Of course I want it to be built well, but do I need to go 16" on center for the structural members? Would 18" or 20" on center be acceptable for the floor joists, wall studs, and roof rafters? I should add that this is New Jersey so the roof will see some snow loading in the winter.
Badfish740 is offline   Reply With Quote
Old 10-27-2008, 05:02 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
with all these shed companies building these sheds, I see them all being built with 24" oc. but if I was to build it for my own use, then I would go with 16" oc. either way would be fine. BOB
Old 10-27-2008, 05:12 PM   #3
I don't know about the others, but in 2002, I built a 10x12 shed similar to yours. I used three 4x4x12 and spaced the floor joists on 16" centers so the plywood decking would fit properly. I just measured the studs and they are also on 16" centers so the T-111 siding would fit properly too.
If I recall, I used the hurricane ties to nail the walls to the floor. I made homemade trusses for the rafters (no ceiling joists). My shed is the only thing on my property that didn't suffer any damage after Hurricane Ike paid a visit recently. The eye wall passed directly over our house.
Hope this helps.
Mike
MT Stringer is offline   Reply With Quote
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
When it comes to a tornado it doesn't matter what the intensity of it is if your house is not properly built to withstand it. If your house is not wind-proofed it can suffer a lot of damage. Follow these steps to prepare for a tornado and prevent... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. However most of the building material that I will be using until I get the stud walls up and a exterior wall up and a roof over it could be expose to some weather without any... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
