Joist Notches - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 09:33 AM   #1
joist notches
when a joist is notched is the joist height reduced by the depth of the notch? is it true if the notches are at the very end tension side?
artmark is offline   Reply With Quote
Old 11-05-2010, 07:59 PM   #2
Rewards Points: 5,336
Why the theoretical questions?
If there's an issue, detail it.
Ron
Old 11-05-2010, 08:23 PM   #3
I am curious a 25% notch is permitted at the end of a joist to sit on a ledger a 1/6 notch in the first and latter third I have a problem joist which may be way to difficult to repair, trying to understand if the code calls for a 2x10 joist knowing that it may measure 7.5 deep after being notched or ?
Old 11-05-2010, 08:43 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
There is a difference in the load and stresses on joist. Each of the stresses have a different allowable stress.
Due to the normal distribution of floor loads, shear stresses are highest near the support and tensile or bending stresses are highest in the middle portion, so the area reduction and/or hole size varies with location depending on the code and type od joist material. Theoretically, shear stresses and compression perpendicular to the span are zero at mid-span. Conversely, the bending or tensile stresses parallel to the span are the maximum in the center portion and near zero at the bearing points. Since the aloowable stresses for shear and tensile/bending are different, the minimum joist depth is determined by the location along the length of a joist.
After all that technical B.S., the cutout depth or hole size generally depends on the location. Since the codes are a simplistic prescriptive standard they show the minimums, but a detailed analysis by an licensed engineer can over-ride a prescritive code minimum if you are willing the pay and engineer for a solution and absorb the liability.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
artmark (11-05-2010)
Old 11-05-2010, 09:27 PM   #5
ok then, if I am sistering a joist and need to notch the ends 1/4" to fit into exsisting framing and drill a hole as low as possible to the tension edge where do I measure from where the notch starts or the edge?
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
