Joist Layout - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 07:32 AM   #31
Stay-at-home GC
Sounds good.
Here is a copy of the Survey/Topo to scale. As you can see I'm still encroaching a fair amount into the Easement
50 years they've never dug up the line. Guaranteed if I put this up they'll be out the next day. I'm just that kind of lucky guy.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-02-2012, 07:35 AM   #32
Stay-at-home GC
Sorry,
not sure what happened when I re-sized the image. 1" = 10,000,000 feet
See if I can fix that.
Old 03-02-2012, 07:55 AM   #33
Stay-at-home GC
Hopefully this one comes through. No longer to scale though (having trouble getting GIMP to lock image aspect ratio)
but it at least gives an idea.
Old 03-02-2012, 08:01 AM   #34
Stay-at-home GC
Originally Posted by robertcdf View Post
posts coming into piers at angles and such, sounds like they might work in your situation, however that needs to be an engineers call.
Is there something obvious I'm missing here? From what little I know of Framing (I feel like I know less now than I did 48 hours ago ) I don't see a glaring error in my design.
Oooh boy, here it comes.....
Old 03-02-2012, 04:37 PM   #35
Old School
Willie T's Avatar
I know you aren't on the stairs yet, but may I make a suggestion?
You mentioned "cutting them". A cut stringer is about 1/3 as strong as a solid stringer... and both are code legal. Something to consider before you shoot yourself in the foot just because most people go the lazy route, and hack up their stringers. Really not the best way to go.
Willie T
Flat Roof: Joist Layout, Slope, & Membrane Help Needed! dutchswan0311 Roofing/Siding 10 10-28-2011 12:44 PM
Flat Roof Joist Layout dutchswan0311 Building & Construction 1 10-27-2011 07:01 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
