Sounds like the joists are hung off sill and tops are slightly above the plane of the mud sill, which is good. (No rim joist on mud sill). Around here, 1/8" to 5/16" is normal, depending on the
lumber size and
location, chart on pp.51;
http://books.google.com/books?id=iwS...rafter&f=false
Be sure to run the ply deck over the sill for floor shear flow in a diaphragm application (not as pictured in other link, following page), follow 3.6 for shear blocking with running joists on page 17 for minimum 90mph wind zone. Check locally or follow engineered plans exactly;
http://www.awc.org/pdf/WFCM_90-B-Guide.pdf
Gary
Clothes taking longer to dry?
